Question about Lenovo IdeaPad S300 59359327 Silver Gray 3rd generation Intel Core i5-3317U Processor1.70GHz 1600MHz 3MB
Upper sise of screen flickering problem - Lenovo IdeaPad S300 59359327 Silver Gray 3rd generation Intel Core i5-3317U Processor1.70GHz 1600MHz 3MB
  • Lenovo Master
  • 27,725 Answers
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Posted on Jan 21, 2013
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
How to get 2 screens, sise by side on my moniter at the same time
right click on the taskbar(the bar which shows active windows or apps usually below your screen) and select show windows side by side for win7 or tile windows vertically for win XP
Nov 07, 2013 | Dell Latitude D800 Notebook
IBM T42 2379 screen flickers very much
We have the T40 model laptops at my work and I have found that when the screen begins to flicker that the internal video cable is beginning to break. It is possible to replace the cable by purchasing a used, and same model laptop from EBay and trading the parts.
To attempt this you will need to remove the keyboard, upper framing, and the framing around the monitor. You should be able to replace just the cable.
Sep 06, 2011 | IBM ThinkPad T41 Notebook
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
Canon EOS Digital Rebel XT: The upper lcd screen info flickers,some of the icons on the screen work normaly, but other icons are lighter and flicker. Im speaking about the portion that displays battery...
It seems you have a false contact in the upper LCD screen, its flat ribbon cable or the connector at the main board.
It is necessary to open it and check it.
It is fairly easy to do it, but if the camera has a warranty, I do recommend you to make it valid.
If does not have warranty, then you may try in do it yourself if you have some experience and skills to fix electronic devices, or pay to have it done.
Best regards,
Jun 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Strobe-like flickering in upper half of Dell monitor
The problem is the inverter on your dell monitor this is very comon.
Jun 15, 2009 | Gateway XHD3000 LCD TV
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Screen flickers
If light is good and picture flickers, then it is either a bad LCD ribbon cable, or cable not well placed into connector, or a bad LCD display, usually it is the cable.
If picture flickers like light is dimming out and coming back, then it is the LCD lamp, probably in need of replacement.
In some rare case a faulty Video card is causing the problem.
Usually to fix this you need to take apart LCD display and upper laptop plate, to reveal the display cable.
Aug 16, 2008 | HP Pavilion dv1000 Notebook
Flickering horizontal lines
sounds like a problem in the horizontal deflection circuit.possibly a solder problem. try re-soldering the horizontal transistor, line coils and yoke pins.
Sep 01, 2006 | Toshiba 50H81 50" Rear Projection...
Lenovo IdeaPad S300 59359327 Silver Gray 3rd generation Intel Core i5-3317U Processor1.70GHz 1600MHz 3MB Logo
133 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
