Bauhn Model ATV-24LEC1 no channels can't get back to first time setup
I tried to scan first time, but external antenna was not plugged in, so with insufficient signal, it came back with 'no channels'. I can't get back to first time installation page, and can find no way to scan again for channels.
SOURCE: My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Posted on Aug 10, 2007
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 105 Answers
SOURCE: Locked out of digital antenna in setup. I had it
1. ensure that you are on the TV tuner when you are trying to scan channels
2. if analog tuner works, but you cannot access digital tuner....the digital tuner is broken
When you turned channels before, did it switch between analog and digital channels seamlessly or did you need to press a button to acces digital channels seperately?
If you accesed digital channels seamlessly, #2 is not likely
If seperately, #2 is very likely.
Posted on Jul 10, 2009
emissionwiz
  • 76109 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
Is there a antenna or a booster that i can use in the house
There are many antenna systems available for Off-the-Air broadcast TV. It depends on space available mainly. There are internal (inside the home) and external mounted systems. Some external antenna can be mounted in the attic as well. External antenna are usually larger and cable of receiving signals from longer distances. They are either directional (point in one general direction at a time) ir omni directional (can receive signals from 360 degrees without physically aiming or pointing the antenna). They also can come with amplifiers/signal boosters, motors (to rotate the antenna for better recepton without manuall shifting it yourself). You can add splitters ti provide signals to more than one TV at a time. The number if channels you receive can depend on many variables so, depending on your location, how far away from the broadcasting antennae you are, and how you mount your antenna, the number of channels & quality of receive signals will vary.
Good news is there are websites on the Internet that can help immensely, so you don't to hire an electrical engineer!
Apr 25, 2017 | Televison & Video
Have lost all channel 2 stations
I assume you are having a problem with OTA channels. On some TVs, if a digital channel doesn't have enough signal strength, the channel list will get edited to exclude it. Have you checked that your antenna is pointed in the correct direction? My external antenna sometimes turns in high winds. Turning it back to the original direction improves the signal strength so that the tuner works. Then go into the Menu and find the Setup or Channels sub-menu to attempt to rescan for channels. (If you add a comment with the model of your TV, I may be able to give the specific sub-menu details for scanning for channels.)
If your antenna has an amplifier, try using the antenna without that amplifier. A few times, the amplifier/splitter attached to that external antenna has been damaged. Then the amplifier becomes a filter and blocks some channels. If you are far enough away from your local station's transmitter and can't receive the signal without the amplifier, replace it.
If another TV receives the stations, the problem is more likely to be the tuner for the TV itself. These can be damaged by a surge from the antenna. The solution is to get a set-top box with an ATSC tuner or replace the TV. Some sites may have replacement tuners (like shopjimmy.com that salvages parts from TVs with damaged screens); however I don't know if they'd have the part you'd need.
I hope this helps.
Oct 15, 2015 | Televison & Video
HOW TO CONNECT ANTENNA TO MODEL # LDVD22-10A
You will need an antenna with a standard 'F' connector (Think Cable
wire end) Find the matching screw on 'F' terminal on back of tv & screw/push on (screw on type of connector is better). Then turn on the tv, go to TV input, & do an auto channel scan. It may take awhile. Be patient. After the scan is over, you should have SOME channels. I say that because Digital signals are the only ones available by antenna, & they ARE VERY SENSITIVE TO ANTENNA LOCATION & ORIENTATION. If you get no or few channels,l move the antenna & do auto scan again.
Samuel Morris
Camtek Of NY
Oct 13, 2014 | Televison & Video
I have apex digital tv. Do I need a external antenna? I scan for channels & it shows its finding but when finished I have no channels.
The set will not pickup channels unless it gets a good signal and a antenna inside may not pickup anything.
Dec 20, 2012 | Televison & Video
I just purchased a ge amplifier antenna for my magnavox tv and i am only receiving 1 channel and its very fuzzy
Your television has generally several receiving modes...such as video 1/2, cable, dvd , satellite, ext antennae. So make sure that it is set on external antennae. Then you will probably need to program in the stations that it is receiving again.. Meaning that ..before bought and installed this product your tv only recognized the channels with reception..now you need to run a new channel scan.. One last thing make sure vcr/dvd/tv button on any other devices you have is in the TV position..or if it is not make sure the signal amp is going into the input plug in the back of that device...rather than directly into the back of your tv... I think the combination of these things will solve your problem. good luck
Jun 22, 2012 | GE Amplified HDTV Antenna 24700
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Sep 07, 2011 | Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I don't have cable TV, so do I need just an antenna or a digital converter box to be able to watch this TV. The Make & Model # is: TOSHIBA LCD TV/DVD Combination & 27HLV95
The TV has NTSC (analog), ATSC (digital) and a ClearQAM (digital unencrypted) tuners. So you do not need a converter box. However, digital TV signals are either all or nothing (sufficient signal for the tuner to process the signal or a no signal message will appear). You should check antennaweb.org or tvfool.com for the channels that are available in your location depending on how the antenna is pointed. (Hills, tall buildings and trees may decrease the channels available in your location.) Antennaweb is very conservative in the list of available channels and assumes an external antenna. TVfool.com provides a list of channels (in each direction) depending on the type of antenna you have. (Indoor antennas usually don't get as much signal as external ones.) Antennas for sale have a color rating that matches the colors given by TVfool.
The manual for the 27HLV95 is available from Toshiba as a PDF: http://www.tacp.toshiba.com/tacpassets-images/models/27hlv95/docs/27hlv95_om_e.pdf .
I hope this helps.
(antennaweb.org indicates that my location will only receive two channels from a transmitter 10 miles away. With an external antenna, I actually get 10 (including the sub-channels) with the majority from transmitters 30 miles away.)
May 18, 2011 | Televison & Video
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Aug 05, 2010 | Axion AXN-8701 7 in. Portable TV
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
Electro Med Services...
