Question about Dell Dimension 2400 PC Desktop
How can I add dual serial pci multi I/O card to my dell 2400 pc?
I need to use 2 com ports 1&2, one is already on the mother brd. but it doesn't recognise the 2nd. port.it came with a NETMOS driver. it does not show up in the bios.it does show up in the device manager as an Netmos Multi 9538 I/O controller. the driver comes up as an error.
thanks.
  • 136 Answers
You can install a dual port pci serial card if you have a free pci slot on your motherboard. This one is from Tigerdirect.
Posted on Jan 27, 2009
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have a Dell Dimension 2400 and it had been working fine until recently. When powering on, it goes to the Dell screen, then there is 2 beeps and won't boot up. I checked the lights in the back for...
I've had a look at the Dell website, at
http://support.dell.com/support/edocs/SYSTEMS/dim2400/en/sm_en/advtshoo.htm
Which basically tells you to do what you've already done.
All I can suggest is you check again, but both ends of the ide connections to mother board and HDD / Disk drives.
If its dusty in there, I'd remove clean and reseat the ram and any PCI cards as well.
Jun 28, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimesion 2400. the usb ports will not work. What do you suggest i do o fix this problem
1. Usually this is a setting in the BIOS (Basic input/out systems) which enables the usb ports. Sometimes a firmware upgrade from the manufacturers web site will resolve this issue. WWW.dell.com ( support).
2. This could be that the usb port have been shorted out. This will require a tech to resolve at the mother board level. Most time this will require a mother board replacement.
Mar 31, 2010 | Dell Dimension 2400 PC Desktop
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Hp pslp-le mother board
this motherboard will take an add-n serial card (PCI slot) to get your nine pin connection. the hieght that this card can be will be determined by the case room you have inside your particular case.
there are three PCI slots on your motherboard, this is where you install the card if the slots are not used by other cards.
Here is a link to the type of card you need---
http://www.perle.com/products/UltraPort-SI-Serial-Card.shtml
Regards
Mar 20, 2009 | HP PAVILLION DV6841TX PC Desktop
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
131 people viewed this question
Alun Cox
