Question about NetGear WGR614 Wireless Router
My laptop cant connect to the internet
I have an ip address but cant connect to my wireless router
  • NetGear Master
  • 32,281 Answers
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Jan 22, 2013
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
jaymac007
  • 42 Answers
SOURCE: Unable to connect to internet when coonnected to VPN
What are you using for VPN? If you are using PPTP, it's probably due to split tunneling enabled. Goto Start > Control Panel > Network Connections > Right click on VPN Network Adapter, then click Properties > then click Networking tab > select Internet Protocol (TCP/IP), then click properties > click Advanced button and uncheck Use Default gateway on remote network.
Hope this helps.
Posted on Jul 08, 2009
redhaze89
  • 854 Answers
SOURCE: ICANT CONNECT WITH MY NEW DELL NETBOOK WITH MY
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Posted on Jul 10, 2009
redhaze89
  • 854 Answers
SOURCE: I cannot access internet when connected to VPN.
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Posted on Aug 16, 2009
  • 150 Answers
SOURCE: I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Posted on Aug 30, 2009
Testimonial: "I received great help! I got speedy replies and great information at a level I could always understand and proceed to work with. Great first experienc"
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
I cant access to the wi fi..it says limited access and no IP address connected. How can I resolve the problems. I'm using SOny Vaio S Series with i3 processor Thanks, Raymond
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 20, 2011 | Computers & Internet
My vista laptop wont connect through the router
you said it says connected to the network but not oline.
Check the IP address on the wireless network connection.
there might be nay static IP address on the wireless connection.
If yes then set to obtain IP automatically.
Click here for more information about routers
Jan 01, 2010 | Linksys Wireless-G WRT54G Router
Cant get the wireless connection through the AP router
first check ur computer IP address (if not getting from DHCP then try static IP address) & default gateway.
Mar 20, 2009 | CTG 54Mbps WIRELESS ACCESS...
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can only connect 1 computer to router
You might need to check if your laptop is able to get a valid IP address when connected wirelessly to the router. You can go to the Control Panel then click on network connections and look for wireless network connection. Right click the wireless network connection then click properties. Click the support tab and there you will see the IP address. You should not be getting 169.254.x.x. Where X represents numbers.
An IP address is very important. Make sure you're getting a correct IP address and it should be the IP address provided by your router. Without a valid IP address, you won't be able to get onlinwe. Your wireless connection can tell you that its connected eventhough its not getting a valid IP address.
Feb 07, 2009 | NetGear DG834 Router
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I cant connect my wireless laptop tp my comp.
Let me know the settings of your Router if needed IP address?
Yes - add your IP address into Network Connection.
No - obtained the setting in your Network Connection.
How to Add or Obtained the setting s of your IP address:
- goto Control Panel
- Double Click Network Connection
- Rigth Click then Properties the Local Area Connection
- Select Internet Protocol (TCP/IP) and select Properties
- Under General Tab they have choices to add or obtained settings.
Sep 20, 2008 | Linksys Wireless-G WRT54G Router
Cant accses router
Pressing and holding the reset button on the router for about 5 seconds should reset the router, but you may need to connect with the router via an RJ45 network cable incase the wireless is not able to set it up The default ip address of the router should then be 192.168.2.1. do not use the windows repair wizard as this totally messes up your pcs ip address, make sure that your network wireless and wired adapters, are set to obtain an ip address automatically You shouldnt change the PPOE or PPOA settings, as they are the settings on which your ISP allows your router to connect to the server. Manually entering an ip address will effect the address of the router so keep the settings as enable DHCP to assign ip addresses automatically. Ensure when you have it running you save the settings so as you can reinstall them if neccasary.
Aug 20, 2007 | Belkin (F5D7231-4) Wireless Router
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
