Question about Dryers
My Maytag Dryer Model MCE800AYQ the bottom dryer says "close Door" even when it is closed and will not operate?
Bottom dryer will not start and says "close door" when it is closed?
    Novelist:
  • 200 Answers
Look at part #4 (door switch) on the link: http://www.partselect.com/ModelFrames.aspx?ModelID=121445&ModelNum=MCE8000AYQ&mfgModelNum=&ManufactureID=1&Selected=55725&Position=5&mfg=Maytag&Type=Dryer&Mark=5 I think it has been damaged. The part is resonablly priced. Investigate further and see if you are confident enough to DIY.
Posted on Jan 21, 2013
  • 32 Answers
SOURCE: Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Posted on Sep 23, 2008
  • 8 Answers
SOURCE: Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Posted on Oct 25, 2008
  • 7 Answers
SOURCE: Indesit IC70C Condensor dryer
We experienced a similar problem and corrected it by closing the drying door and then hitting "OPEN" followed by closing. Sometimes we use a tool to release the catch and then close the door. We have not seen this problem return.
Posted on Feb 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
  • 949 Answers
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Posted on Apr 23, 2010
Testimonial: "Great advice, thank you for your help."
Will not turn on
If I remember correctly, this unit has too door catches, one on the bottom and other on top. When the door is closed, it can only latch at the bottom and not the top, the door switch is at the top only. Try push the top of the door to assure it is closed completely. This should work to solve this issue.
Jul 11, 2011 | Maytag Neptune MDE6700A Electric Dryer
Dryer makes a ticking sound when the door is closed but wont start. If I put the dial on off, then the ticking goes away....help
the ticking noise is the timer, you dryer is not starting:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 25, 2011 | Maytag PYE2300AY Electric Dryer
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Kenmore dryer doesn't recognize when the door is closed.
first try unpluging the dryer for 5 minutes and then check it,this resets the computer board just like your house computer or you could have a bad door switch or something wrong with the main board,the main board is alot more than the door switch,if you have a meter you can read out the door switch,there should be a tech sheet in the dryer maybe taped to the side wall behind the bottom panel that might help you out.
Jan 14, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Does the drum light come on if the door is opened ? Those doors can be tricky, they have 2 latches, one top and one bottom. Close the door, give a slight push at the top of the door and on the bottom, the latches will become easier to close with use. Try it for now though. Other than that, I've seen loose wires from transportation, poor outlet wiring, and even breakers not "on" in my travels of service. Good luck
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Phil
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
I just replaced a broken belt on a Maytag dryer Model LDE5005ACE and now have no power. Checked breakers and power...no problems there. I did break the door sensor, but since it is just an open/close...
the door sw is probably your problem then. it needs to be closed to operate but should open with door to stop dryer. also check if belt switch, it is not pressed.
May 02, 2009 | Maytag Dryers
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
