Question about Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos home booster
I've got a Grundfos Home Booster that until recently has been working fine. It has always provided sufficient pressure to have four outlets running at the same time with good pressure. Now, whilst one outlet runs well as soon as another one is turned on the pressure drops significantly, even though the pump kicks in at the same setting as before. Pump is 6years old. Any idea please???
2 Suggested Answers
  • 3 Answers
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
Posted on Jul 09, 2009
I have low pressure at house, There is no problem
I am just guessing but it appears there is a restriction such as a partally closed valve.
Sep 01, 2013 | Grundfos Pumps Grunfos UP15-42F 1/25 HP...
I have a problem with mq booster pump every 10 seconds kicks back and kicks on i am check the showers no leaks everything is ok please tell what can be a problem
Grundfos said the problem of on off every few seconds was air in the line. Then
later admitted it was the control unit. After replacing two units in 2 yrs I replaced
it with a standerd pump pressure switch.....Runs fine
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have a grundfos type ch2-50, it wouldn't start so i replaced the capacitor, still won't start any idears
CHECK ALL WIRING FOR A SHORT. SEE IF THE IS A RESET BUTTON ( SHOULD
BE RED) AND TRY TO RESET. CHECK YOUR BREAKER.
Sep 01, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Has anyone at this site had much experience with a Grundfos booster water pump and its dependability?I am considering the purchase of one for my daughter's home. She has a 1500' entrance water pipe running...
You would be better off with a brand that has better representation than Grundfos. Several of our commercial customers change to brands such as Armstrong or Bell & Gossett the first chance they get because Grudfos is less reliable and getting parts or service on them much harder.
Apr 28, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Grundfos JPS4  1 HP Pressure Booster Pump  Logo
71 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
