Question about Alpine Car Audio & Video
Alpine ai-net sea-8081 installation manual - Alpine Car Audio & Video
3 Suggested Answers
rteemon
  • 578 Answers
SOURCE: Alpine Sound Field Processor
check the setting menu and u will see how to
Posted on Jul 07, 2009
  • 1015 Answers
SOURCE: I have my cd changer (alpine) plugged into the
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Posted on Jan 09, 2010
What are the switches for on the back of Alpine c da 9984
Those are for Ai-Net accessories (CD changer, amps, etc). If you're not using anything with Ai-Net, then I suggest you leave them as they are.
Feb 07, 2016 | Alpine Car Audio & Video
Ai-NET cable is cut, wire splice male aux cord
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
Sep 29, 2013 | Alpine CDA-7863 CD Player
What is Ai net
ai net is simply alpine's upper level line of decks. they have their regular line and ai net line. just like kenwood has their normal line and their upper level excelon line. ai net uses different cables to connect with changers and aux items than the regular line.
Apr 18, 2010 | Alpine CDA-9883 CD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Want to know if I can use the line-level inputs from the CD Chgr
Your alpine unit is the old "M-BUS" the other adapter you are talking about is an "AI-BUS" adapter. (Hence the model numbers beginning with CD"M" or CD"A" ...)
Look for an Alpine M-Bus to RCA Input adapter.
heres one on eay for less than 10.00 including shipping.
http://cgi.ebay.com/For-Alpine-M-Bus-to-stereo-RCA-adapter-cord-cable-8-pin_W0QQitemZ310117370938QQihZ021QQcategoryZ60208QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Feb 09, 2009 | Alpine CDM-7857 CD Player
Can i connect my alpine tda7592r headunit to an to an ipod thou the aux
CLICK HERE for your owner's manual.
Yes, you can purchase the following Ai Net cable that works through the changer port on the radio...
It is available HERE.
Or available at your local installation shop.
Thanks for using Fixya - A FiXyA rating is appreciated!!
Jan 23, 2009 | Car Audio & Video
Aug 27, 2008 | Car Audio & Video
How do I add an Aux input?
Does your Alpine support the ALPINE AI NET adapter?
If so, this will work;
http://www.installer.com/item/display_item.php?it=alp-ai-35mm
Otherwise, you might want to get an FM Transmitter;
http://www.amazon.com/Griffin-White-iTrip-Transmitter-iPod/dp/B0000AAAPF
Best of Luck.
Please RATE my solution BELOW.
Nov 24, 2007 | Alpine CTA-1505
Aux input problem
Here's the link for the manual: http://vault.alpine-usa.com/products/documents/OM%20CRA-1667RF.pdf
Aug 19, 2007 | Alpine XMA-T200RF FM / AM Receiver
CDA - 9833 AI-Net issue
If the radio was still plugged in when you cut it (such a BAAAADDD idea....) it likely shorted the data pins to the power pins which fried the AI net processor. There is no fix for that. It's toast.
Aug 20, 2006 | Alpine CDA-9833 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
