Easy touch 42inch lcd tv black screen
The tv turns on then says easy touch then goes straight to a black screen also none of the buttons on the tv work other than standby button.
    Genius:
  • 1,003 Answers
Replace power supply and mainboard
Posted on Jan 21, 2013
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: LCD TV won't turn on, Screen and Standby light blink
I had a similar problem which I have partially solved. The power light flashing could be due to a shorted electrolytic on the power supply board but in my case it was a shorted IC on the main board, the one with the input connectors. The IC marked 7001 shorted and got hot enough to melt the plastic. Replaced it with a new one from Mouser. The supply measured on the end of inductor 5001 farthest from the IC reads 12V now. This is a surface mount part and has a pad on the bottom that may be soldered to a pad under it. I had to cut the IC apart carefully with a Dremel cutoff wheel to remove it. That fixed the problem with the light and the remote now turns the TV on and off so the logic is working.
I now have the problem of the backlight not turning on. The driver board, the ones with the transformers, are made by Intechwave, the only info I can find is here: http://www.peopleworks.co.kr/kor/product/product_list.php?intDivision=4&intClass1=16&intClass2=41
This a 45kHz RF driver and it is not starting. If I can figure out why I'll post it for all the people who reported slow or no turn on of the backlight. These boards should have 24V between the red wires on the connectors and ground, as mine do.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: LG LCD 37'' standby problem
if you want i will buy the tv from you
Posted on Feb 23, 2009
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
Television stuck on black philips screen will not do anything except flash off and back on to same black philips screen.
Sounds like the media/main board is going out. You can change those out really easy with just a screw driver.
Check ebay with your part number off the board. Start with you tv model number and the the BOARD part number. Alot of board look alike but there aren't.
Also..
shopjimmy.com is a good place.
Good Luck.
Sep 11, 2015 | Philips Televison & Video
My HP Pavilion G6 laptop screen turns on and then goes blank (black)
When the screen turns on does it show anything or does it turn on and go to black?
If it goes to straight black it could be two things typically.
1. The LCD screen is having an issue. Connection cable / LCD screen itself.
2. The Graphics Card has gone out.
Jan 19, 2013 | HP Pavilion G60-235DX notebook
Tv has no picture but sound is ok
First of all, change the input device to something you know works for sure. Look for any jammed buttons on remote or on control panel. (This can happen, if you inadvertently sit on the remote hidden under a magazine or newspaper) Check the picture settings to ensure that these are ok. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Black box on screen
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Feb 12, 2010 | Sharp LC-19SB14U 19 in. LCD TV
Koss KLD2700 LCD TV no picture
http://www.fixya.com/support/t860220-screen_blank
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Televison & Video
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Electro Med Services...
