Question about Homelite Garden
Simply Reliable Homelite chain saw UT 10766A
Need Carburetor Zama C1Q
SOURCE: need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Posted on Feb 06, 2009
slohry
  • 87 Answers
SOURCE: I need a manual for homelite chain saw 14" ut no. 10655 ser.
50:1 if you use good oil (i.e.Husqvarna, stihl, echo)
32:1 for lesser quality oil.
Download manual here. have UT# available
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
SOURCE: Homelite XL, UT 10618-A, 14
This probably is a worn out automatic oiling diaphragm and plunger assembly. If it is like my Super 2, it is right behind the clutch and sprocket. I had to take the sprocket off to get to the little plate held by three small screws. You probably have to remove the plastic covers first to see this stuff. After removing the screws, the diaphragm and plunger should peel off either the plate or the engine housing. Now the fun starts. I found a parts supplier that listed a picture of the little demon and the price was about seven dollars. But I didn't bookmark the site and now I can't find it again. If all this info matches your saw, and you find a parts supplier, please post it. Good Luck!
Posted on Jul 08, 2009
  • 124 Answers
SOURCE: what is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 13, 2009
  • 4088 Answers
SOURCE: How to remove plastic limiter cap on (H) carburetor adjustment
If plastic cap is present, it should just pop off with a thin sharp hook. Look carefully at the screw heads--they may be 'D' heads which require a special screwdriver and are supposed to keep owners from moving the screws (thank the EPA for these). Only authorized saw servicing dealers have access to these tools and therefore are the only folks allowed to adjust these saws. Being nonconformist, I made my own by drilling the center of a 1/4" rod, sawed off one side somewhat and welded a flat across the cut. Hope this helps!
Posted on May 11, 2010
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
How do you rebuild a Zama carburetor ?
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
Jun 05, 2014 | Homelite Carburetor Trimmer Blower...
Stihl fs80 trimmer
have to go through a dealer. they have the only access to those. they can print them off for you.
Aug 02, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
ZAMA CARBURETOR REBUILD
Unless you really know what you're doing i wouldn't advice it be carried out by a novice. Carbs contain small one way valves that can get damaged. Avoid using airlines to clean and blow out carbs as these can damage the valves. Diaohrams, gaskets and needles are pretty straight forward tho.
Jun 14, 2012 | Stihl Trimmer Zama Carburetor...
I would like to know where I can buy or order an inlet manifold boot for Homelite 330 Chainsaw. I am having difficulty finding this part.
hi photobil
pauly46 here
here is web site for parts
http://www.odref.com/homelite/chainsaw/ut-10540.pdf
go to page 9
part ref # 26 number 93838b boot connector
save a copy of this file
here is another web site
http://store.chainsawr.com/collections/homelite-1?page=11
he has had them but o/s at present but order 1 anyway
check out www.chainsawr.com , go to parts by brand homelite ,
cheers hope it helps
pauly46
May 29, 2011 | Homelite Zama Rb3 Carb Kit 330 Chainsaw...
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Garden Logo
63 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
