Question about Frigidaire FRS6R5ESB
Both the refrigerator and freezer has stopped cooling, with the refrigerator going out first and then the freezer getting noticeably warmer a few days later. The refrigerator still seems to be working. This problem started around christmas and the repairman replaced the entire circuit board stating that it was the problem. After that it worked fine until about 3 weeks later it started exhibiting the same behavior. The fridge still sounds the same, nothing different except that it no longer cools, no matter the temperature setting. Help Anyone?
  • Official Brand Answer
  • 4,342 Answers
Hello woolcocky - Do you hear anything running in the machine compartment? Does the compressor kick on and off? If it is not, contact a certified technician immediately, sounds like the refrigerator may be experiencing a coolant leak or an issue with the internal sealed system.
Posted on Jan 23, 2013
  • woolcocky
    woolcocky Jan 28, 2013
    The unit was running continuously without it kicking on or off. I will definitely need to contact a technician because the unit burnt out this morning. my freezer is lined with black soot, so no doubt a small fire
catriver
  • 878 Answers
SOURCE: Fridge and Freezer working intermittently; not getting cold and making a vibrating sound
Dave, what you are hearing is the overload kicking out on the compressor. It's one of two things, either the compressor is failing or PTC (overload, relay) is going bad. I haven't seen too many PTC's fail on Frigidaire, but I have seen a lot of compressors failing. Your refrigerator will have a 5 year warranty, parts and labor if the compressor is at fault. You would have to do some tests on the compressor to determine which one is at fault. If you have a clamp on ammeter you can see how many amps the compressor is drawing during start and run. The compressor should have a label on it with the amperage information. You could just replace the PTC, part number 218721119 and see if the problem goes away but you could be throwing away money here if the compressor is the problem. With out being there, my guess would be the compressor itself. Catriver...post back.
Posted on Dec 09, 2006
  • 125 Answers
SOURCE: Refrigerator not cooling...bad odor.
check the condensor fan motor to see if its working and check the condensor for dust etc. the condensor fan is in the back on the bottom, you may need to remove a panel to access the fan. if the unit is running and the fan is not turning or if it is turning slow replace the fan. If possible check to see if the fan is getting 120 volts.
Posted on Jun 25, 2008
SOURCE: The freezer works very well but the refrigerator is not cool enough
check if fan in freezer is running , stryo is air diverter leave alone. ck frz temp rkm
Posted on Jul 11, 2008
  • 2251 Answers
SOURCE: fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Posted on Mar 22, 2010
  • 949 Answers
SOURCE: Frigidaire White 16.5 cu. ft. Top Freezer
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Posted on Apr 18, 2010
Every few month, the freezer and refrigerator compartments progressively get warmer and warmer causing food spoilage. After a day or so, the refrigerator returns to normal functioning.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Cooling problem with a ge top freezer refrigerator
I have one that did the same. The coil in the back of the freezer was frosting up because it wasn't defrosting like it was supposed to. I noticed that the thermostat looked damaged so I ordered a new one from sears parts direct which by the way will show a diagram of the model you have. I just installed it last night so I will post how it comes out. This morning the freezer has a burnt smell but I am hoping its from the defrost not working for a while!
Mar 03, 2008 | GE Hotpoint Top-Freezer Refrigerator
Frigidaire FRS6R5ESB Logo
198 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
