Question about YouTube Videos
You tube freeze
It freeze lots
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Update your adobe flash plugin or install Chrome.
Posted on Jan 21, 2013
Freezer runs continuously even on low setting.
Check you tube just go to you tube and type in what the freezer is doing .I've found a lot of things on there .
Sep 15, 2014 | Bush CF143GB Chest Freezer
Ice maker works fine but ice will not vend out of the storage bin. Ice freezes in the vending area
Check the door flap where the ice comes out into the dispenser. The number one cause of the ice build up in the dispenser chute is caused from warm air leaking into the freezer and clashing with the freezer air.
May 30, 2012 | Refrigerators
Compressor will not engage,fuuly charged and relay and fuses ok
YOU COULD HAVE FAULTY CLUTCH CYCLING PRESSURE SWITCH. YOU COULD HAVE A LOT OF MOISTURE IN THE AC SYSTEM.CHECK EVAPORATOR LINE GOING IN THE FIREWALL TO EVAPORATOR IF YOU SEE ICE ON EVAPORATOR LINE TO FIREWALL.YOU HAVE A RESTRICTION IN ORIFICE TUBE IN EVAPORATOR OR LOT OF MOISTURE FREEZING UP IN THE SYSTEM.
May 12, 2011 | 2006 Mercury Milan
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
The drainage tube in our GEProfile keeps freezing
After defrosting, take compressed air and actually make sure that you can blow air through the tube....if the tube is open then there is no way that the water should not be going down....
Heatman101
Apr 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a kitchen aid refrigerator KSRG22FTSS01 that the icemaker continues to freeze up in the delivery tube, any suggestions why
This is the fill Tube to the Ice maker tray. It is freezing because the water valve is leaking a little even when it should be closed. This leak is now freezing your fill tube. If you defrost the tube it will work untill it freezes again. The only solution is to replace the water valve. The valve part number for your machine is 4389178
Jan 14, 2010 | Refrigerators
I have water leaking somewhere at the back of my icemaker. It runs down the inside of the back panel and freezes around the fan which will make noise and finally stop the fan. Where should I look for leak...
Look at the back of the inside of unit. You should see a water inlet tube. This tube can get frozen and crack or brake. Also, if the auto-defrost timer is not working, your compartments may have different temp readings or you can have lots and lots of icebuildup
Sep 16, 2009 | Refrigerators
Ice Maker Not Making Ice BUT making a "trying" sound
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
Icemaker does not work
Hello Netmindr32,
You will need to replace your inlet valve. The problem is the water is slowly leaking into your icemaker fill line and freezing up. You will have a double inlet valve and the line going to your dispencer may be working fine but the one going to the icemaker is not sealing off. Be sure to defrost all the ice out after replacing the inlet valve. And please allow several cycles of your icemaker before it makes its first batch. It can take 2-3 cycles to fill lines and filters depending on your model. Lots of luck to you and please let me know if this helped you. Mca0824@aol.com
Apr 30, 2008 | Refrigerators
YouTube Videos Logo
22 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
