Question about Whirlpool LHW0050PQ Front Load Washer
Stuck in wash cycle
Wash cycle stuck
  • Whirlpool Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 22, 2013
Washer is stuck on one wash cycle
What cycle ? Did you ck pump for trash ? Any error codes pop up ? Need more info .
Oct 14, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
Bauknecht gsf 4481
The timer is not advancing to the next cycle. Replace the timer.
Mar 13, 2014 | Bauknecht Dishwashers
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Machine is not moving through the cycles
It sounds like the motor in the timer is bad. This may require replacing the whole timer or just the timer motor in some cases. I hope this helps.
Mar 20, 2010 | Whirlpool Washing Machines
It is stuck on wash cycle
The cycle select knob may need to be replaced, or u may have a bad solenid in your washer. If a solenoid is bad, it wont allow the washer to go past a certain point in the cycle.
Nov 28, 2009 | Microwave Ovens
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
