Question about Electrical Supplies
Can you put a dimmer on utilitech led lights
Can a dimmer be put on this led light??
2 Suggested Answers
info30036
SOURCE: if the legrand dimmer 400w - pro21 can function
We also had problems with dimming LED light bulbs until we found these bulbs at LED Lighting Wholesale. Check them out!
http://www.ledlightingwholesale.com/c/64/par-20-dimmable-light-bulbs-led-lighting-wholesale-par20
Posted on Jun 02, 2012
Utilitech Pro, model 0595683. Can I use a dimmer with this LED fixture?
It appears, no you can't use a dimmer on these lights. You can try a CFL / LED rated dimmer, but it still may not work
Jan 06, 2016 | Electrical Supplies
The Utilitech Xenon puck light kit 5 pack, it comes with a dimmer that plugs into the power source, how does the dimmer work exactly? Doesnt say in the instruction. Any help is appreciated
dimmer switches used to work by controlling the current flow through a resistor. They were rather large and were prone to getting hot. Modern dimmers use an electronic process where the sine wave is cut at various points of the wave and that restricts the amount of power available to the motor
because of the voltage used I suggest that you get an electrician in to complete the installitation.
Jan 10, 2015 | Cars & Trucks
We have a utilitech sump pump model #0313508. I am looking for the plastic, or metal standoff through which the float operates.
You might have to make your own. Think of stainless steel rod etc. Utilitech is not a universal brand. Parts are not available and the whole unit is expensive. Grainger does not have anything and it appears that the exclusive provider is lowes.
Sep 20, 2014 | Electrical Supplies
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
