Question about Husqvarna 450 e-series 18" Chain Saw
Fly wheel seemds locked up on Husqvarna 445
After working fine for hours with my Husqvarna 445 the fly wheel break just engaged and the chain will not spin..... so i opened up the case to give it a good cleaning.. after closing the case it is now very hard to pull the cord ... i am not able to get it started
  • 181 Answers
The flywheel does not have a brake,the clutch side has the break.if you have the chain side cover off the brake is no longer on the clutch drum.the fly wheel is on the oppiset side (starter rewind).take the starter rewind off and see if the motor will turn.if hte motor turns the problem is in the clutch side.if it doesn't the problem is in the flywheel side.the ignition coil has been known to loosen up.the screws streitch out from heat.check the air gap between the flywheel magnets and the ignition coil.should be .10 to .12 inches.if problem is on clutch side check to make sure that the springs are on between the clutch discs.they have been known to break and that does not let the chain spin on bar.any questions get me an e mail
Posted on Feb 11, 2009
  • 6 Answers
Firstly, try pulling the chain brake handle back into the running position - you should hear a click if the brake is working correctly. Then try rotating the chain by hand - if it rotates your problem is solved!
If this does not work you should check to see that the chain brake cover is seated properly on the saw. You may be binding the clutch with the chain brake. Remove the chain brake or clutch cover again and attempt to reset the brake by pulling it to the rear - again you should hear a click. Reinstall the cover and ensure it is seating flat to the main body of the saw. Then ensure the chain is loose enough to rotate by using the chain tensioning screw - the nut or nuts that hold the chain brake to the saw will have to be slightly loose. The chain should have a very minor bow to it when you look at the bottom of the bar. Do not forget to snug the nuts down firmly when your a finished.
Should these suggestions fail you might consider going to your chain saw shop and have them look at it as the chain brake is an important safety item and should function correctly at all times.
Good Luck
Posted on Jan 27, 2009
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Tried to replace my chainsaw on my husqvarna 445, but the brake seems to have not released, so I can't get it back together
Not an easy thing to reset either. You can try putting chain brake back on with the retaining nut(s) loose so don't go flying. Now place the reset handle as far forward it will go. While pressing hard with hand at the chain reset location of the cover pull back on the reset handle. This should reset the brake.
Note this will not always work and sometimes you need a saw shop to help reset it.
Apr 02, 2015 | Husqvarna Garden
Why does my 445 husqvarna die after I start it in cold weather -17c
if the fresh air door is open to carb box, close it and you need to get a cold weather kit,which consists of air cleaner hood and a fly wheel suction reducer
Feb 22, 2015 | Husqvarna Garden
I broke the throttle trigger on a 445 Husqvarna chainsaw. I removed all of the screws etc from the orange handle bar. I am still unable to separate the two orange pieces. I do not want to force and...
The two halfs of the rear handle do not seperate, once you have removed the r/h side grip you can remove the throttle lock, you then need to remove the pivot pin from the trigger with a pin punch, the trigger can then be pulled down and out, you may need to disconnect the throttle wire from the carb if you cannot drop the trigger far enough to remove the wire from it.
Jul 02, 2011 | Husqvarna 16" 457cc Prosumer Chain Saw ...
Hi i have a Husqvarna 445 18" 45.7cc the automatic
Verify you have oil in the oil fill tank. Try cleaning inside the drive sprocket cover. Release the chain tension and carefully dislodge the bar and chain assembly. Clean sawdust and debris from behind and inside the housing and behind the bar. Use a wisker wire to clean the through ports and channels on bar( these ports are the path that the oil travels to the drag groove that the drive links on the chain uses to pull the oil to the tip of the bar).
Please refer to this link below for your saw maintenance-
http://www.chainsawsdirect.com/manuals/HUSQ_445_MAN2.pdf
If this does not correct the problem contact Husqvarna customer service or a local service repair.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have tried everything but cover will not go back on the husqvarna 445. there is just not enough clearance for the band to go back onto the drum. have tried even adjusting the band tension but that...
The problem you are experiencing is very common. Many people remove the side cover with the chain brake applied or either the brake becomes engaged after the cover has been removed. You will need to reset the brake before you can install it. This is a little tricky but can be accomplished. I find that it is done fairly easy by carefully clamping the side cover in a vise, and using a good strong pair of needle nose, span the "rotator" (star shaped wheel) on the brake and with another pair of pliers, grab the needle nose pliers and "twist" the brake into the disengaged position. Hope this is explained well enough to get the job done.
Mar 04, 2011 | Husqvarna Chainsaw Piston Kit for 61...
Brake band will not go over fly wheel
A link to an IPL a 2008 Husqvarna 235E follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2008/I08000/I0801001.pdf
It includes a good illustration of the brake and its' components. It is likely the chain brake is released and will need to be engaged to enlarge the brake band.
Reset Chain Brake
Immobilize the clutch cover (blocks of wood on a flat surface to protect the finish) in a vise or with a large C-clamp to a work surface.
Use pliers or a crescent wrench and rotate it clockwise until it latches open. This will require some force. A slight modification reported in a testimonial to the above method follows;
" Thanks for the help. I took your answer and modified the fix a little. I placed the cover on loosely and then moved the bar handle into the right position in order to engage the spoked wheel, then rotated the handle back until the cover fit right. Thanks, SG "–NameRemoved
All Husqvarna OMs and IPLs can be found here:
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 21, 2010 | Husqvarna Garden
How do you get the fly wheel off of a 1979 165cc
A model number would have been helpful.
I suggest a length of nylon rope (nothing left behind) be used as a piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises
Some pry them off (breaks cases, may damage points on yours), some smack the crank with a hammer (your crank), Some try holding the fly wheel and break cooling fins that effect balance. Professionals use a puller (call a local saw shop they might do it for a small compensation). HTH
Lou
Feb 17, 2010 | Husqvarna Chain Saw 20" Bar
Changing the chain on husqvarna 445
make sure the chain brake is off. Then undo the two retaining bolts and take the cover off.
Sep 19, 2009 | Husqvarna Forest & Garden #966906636 445...
Husqvarna 450 e-series 18" Chain Saw Logo
1,106 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
