Question about Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR
Space Bar on Zagg keyboard not working - Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR
Why is there dead spot on keyboard?
have your kindle reflashed,software is messed up
Nov 25, 2015 | Amazon Kindle Fire HD
Light stays on charging, doesn't shut off..... Doesn't hold a charge
Hello, Pull the electric cord and let the battery run all the way down. Pull the battery out and try powering up and down on the switch without the battery in. If that works then you have a bad battery.
Oct 04, 2015 | ZAGG Apple Folio Case With Keyboard For...
How do I underscore from keyboard without key
On my on-screen keyboard, it's on the numeric keypad, just to the left of the space bar.
Nov 08, 2014 | Lenovo Tablets & eReaders
Can not get keyboard to pair with ipad
Make sure the keyboard has been fully charged. Most BT keyboards do have provisions to get power from the iPad.
Jul 18, 2014 | ZAGGkeys Cover and Bluetooth Keyboard for...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Zagg keyboard Will not work after connected by Bluetooth in ipad2
I have a Zagg keyboard for my iPad mini. I found the same thing happened but then realized it only works in most apps, not all. For example it doesnt work when typing in a password in settings. Try you keyboard in an app like notes. Also make sure you haveheld down the power for long enough that the light is red for 5 seconds.
Sep 28, 2013 | Apple iPad 2 Wifi 16GB
My space bar disappeared
The ipad is different that it has no space bar for typing email adresses in safari but will show space bar for search box.
Sep 24, 2012 | Apple iPad (16 GB) WiFi Tablet PC
When keyboard comes up on IPad, the space bar is missing. I know that it was there at first. How do I get it back?
What app are you in? The iPad's software keyboard is not always the same - it changes depending on what context you're in. For example, it will remove the space bar and display web symbols when typing a URL (web address).
Feb 14, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Space Bar
Sounds like something's not making contact properly. I don't think you're going to have much success getting that key to work, at least on a permanent basis.
If your computer is under warranty, this merits a replacement keyboard. If it's not under warranty, replacement keyboards can be found online from parts providers or on eBay. Just make sure to get the right one for your model. You can usually install them yourself quite easily (typically three or four screws, five minutes or less). If you don't feel comfortable doing it yourself, it's a very basic repair and if a service provider sounds like he wants to charge you too much, he probably is. Keyboards run in the $30-70 range depending on your model, and I wouldn't pay too much more than $30 to have it installed. Forget places like the Geek Squad; a local shop can probably do it cheaper. I'd say altogether you're looking at $50-100 installed.
And as for your other question... I work servicing computers, and Toshiba machines are by far the worst products I've encountered. I don't recommend them to anyone. I haven't had much luck with other Toshiba electronics, but then again I haven't used them extensively either.
Hope this helps.
Javabytes
Nov 18, 2007 | Toshiba Portege M205-S810 Tablet PC
Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR Logo
574 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
