Question about HP Photosmart C3180 All-In-One InkJet Printer
At starting automatic page print
When I turn on the printer, everytime it print a paper with dotted ink.
So it is wastage of ink and paper.
Please let me know the troubleshooting.
  • mahbub_shahi Jan 27, 2009
    I appriciate for your answer.
    I going to try.
  • mahbub_shahi Jan 29, 2009
    Still I have the same problem.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
Turn off the setting align ink catridge
go to SETTINGS , then go to DEFAULT of FACTORY DEFAULT click here, turn off PRINTER then turn ON again , see what happens , let me know , AJ
Aug 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Automatically prints
Print the test page and place it into the scanner, remember to place the paper in the correct direction. Then press the start scan button on the printer. Let the scanner do the scan and if it is successful, the printer is ready for use. If it failed, then the orange led for check paper will flash slowly. If every thing is done in the correct sequence but get failed from time to time, then you may need to get the scanned image of the test page to see what the scanner is seeing.
Jun 26, 2008 | HP PSC 1510 All-In-One InkJet Printer
Hp photosmart c3100 series ne s'instal pas sur vista
Everytime I turn off the printer and turn it back on, automatically it start printing an test page; with lines, blocks, gray blocks to test the ink. How do I change the printer to stop the test page?
Thanks for your help!
Emily
May 20, 2008 | Office Equipment & Supplies
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
How to avoid unwanted stuff in web page printing
First you need to do is, Select the appropriate text in thre Web Page by avoiding the unwanted text then used the copy and paste options in the word.
Let me know if your problem is solved and rate me as FIXYA!
Apr 06, 2008 | Computers & Internet
Printing Test Page
you probably need to align the print cartridges. you can usually do that through the advanced printer oprions
Mar 25, 2008 | HP PSC 1350v All-In-One InkJet Printer
Dots on page
shivan, did you change the toner if it yes then open printer and clean the surface of toner and the roller see is there any dust or ink powder is there. bye
Sep 22, 2007 | Brother HL-5280DW Laser Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
