Question about Acer Computers & Internet
Acer wont start - Acer Computers & Internet
  • Acer Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
Computers need Power and Data to travel through every working device and continue an uninterrupted cycle and have an end so any faulty leads will end up with a computer error.
Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Hope this helps.
Posted on Jan 21, 2013
My packard acer wont turn , power light comes on when pluged it , but wont power up
Packard Bell, Acer? Which manufacturer? Remove the power, remove the battery, remove hdd and RAM. Plug in the power supply and press On. It will complain that is has not any RAM etc. If it does, insert one RAM chip and try again gradually if not you have a motherboard issue.
Oct 05, 2016 | Acer Computers & Internet
Acer aspire xc-603 wont start up
can be a dead CMOS battery or some Power supply issue.
the best thing is to contact the official Acer support service.
Jun 01, 2016 | Acer Aspire Xc-603 Compact Desktop/...
Wont start up.
maybe a corrupt or missing file,try starting in safe mode
Jun 14, 2014 | Acer Aspire Z Series All-in-one Touch PC...
The sound wont work and iv'e tried holding Fn and the sound buttons and it wont work what else can I try
Try using acer recovery to reinstall the application and driver.
start/programs/acer/recovery
Apr 02, 2013 | Acer Aspire 9500 Notebook
Acer aspire laptop wont start after I interrupted a service
you should return it to the supplier because they have a security password for your acer laptop.
Nov 09, 2009 | Acer Computers & Internet
Acer laptop wont start
pls try to restore or repair thru backup disk u made when u bought pc
otherwise follow this procedure for restoring the OS without backup disk but data might be lost on C drive only not D or other drives pls take care
cer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
pls rate FIXYA if it helps
Mar 13, 2009 | Acer Aspire 5720 Notebook
Computers & Internet Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
