Question about Maytag MDE3706 Electric Dryer
Heating element replacement - Maytag MDE3706 Electric Dryer
    Sergeant:
  • 211 Answers
There should be more to your model number..I.e. Age,akw,aye,azw although the heating element part number seems to be the same, it is good to have the full number. Here is a link to the parts: http://www.partselect.com/ModelFrames.aspx?ModelID=125114&ModelNum=MDE3706AZW&mfgModelNum=&ManufactureID=1&Selected=58908&Position=1&mfg=Maytag&Type=Dryer&Mark=1
Posted on Jan 21, 2013
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Model 790.96009601 I replaced the heating element that burned out. New heating element does not work.
The replacement heating element could be defective, not burned out. Also, the replacement element could have been installed incorrectly.
Oct 29, 2014 | Kitchen Ranges
Temperature sensore probelm
make this test and fix it. God bless you
Heater
This is the most common reason why your dishwasher is not drying. To check this remove the toe kick, remove one wire from heating element and check ohm reading. Compare the reading to the tech sheet or service manual. If it has no continuity at all replace the element. Make sure the element is getting power. To do this connect voltmeter to each lead of the heating element then select a dry cycle you should have 120 volts if not the problem is in the control. If it does have power and does not heat up replace the element. The heating element is easy to replace
Timer/ Control
This is not as common as the heater but can fail. To check this select a dry cycle and check to see if the heating element has power if it does not replace the control If the element does have power and does not heat up replace heating element.
Jul 24, 2013 | Dishwashers
Water not heating
Heater
This is the most common reason why your dishwasher is not drying. To check this remove the toe kick, remove one wire from heating element and check ohm reading. Compare the reading to the tech sheet or service manual. If it has no continuity at all replace the element. Make sure the element is getting power. To do this connect voltmeter to each lead of the heating element then select a dry cycle you should have 120 volts if not the problem is in the control. If it does have power and does not heat up replace the element. The heating elements is easy to replace9f39612d-286d-4ab9-9ae7-61bc229b8105.gif.
Timer/ Control
This is not as common as the heater but can fail. To check this select a dry cycle and check to see if the heating element has power if it does not replace the control . If the element does have power and does not heat up replace heating elements
May 23, 2013 | Dishwashers
It's not heating and we've replaced to different heating elements
the dry is not heating up. we replace the heating element and thermostat and thermal fuse., It sill doesn't heat up
Nov 10, 2011 | Amana ALE866SB Electric Dryer
Model #66516352301 replace heating element
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 06, 2011 | Kenmore Dishwashers
The dishwasher is not heating up during washing or drying - it appears the the heating element has broken - is it easy to repair
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Dishwashers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Maytag MDE3706 Electric Dryer Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
