Intermittent blue screen with resolution display
At irregular intervals screen goes blue then picture resolution eg:1080i (1920 x 1080) 50hz is shown for 1sec then picture returns to normal
    Genius:
  • 1,003 Answers
May have to swap mainboard
Posted on Jan 22, 2013
  • 6 Answers
SOURCE: the display only goes between normal and zoom
This is an EDTV capable of 1080i over component cables. It will also display 480p & 720p. Most likely its the video source determing the resolution you are seeing.
Posted on Nov 28, 2008
  • 115 Answers
SOURCE: How do I change my
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Posted on Aug 09, 2010
e-Guru
  • 3917 Answers
SOURCE: Experiencing blue screen when first
Hi
Check if all the necessary cables are correctly connected. Please check if the cable contains the digital TV signal supplied by your cable TV service provider. Please make sure the correct signal source is selected: Press the "menu" button on the remote control, select "External Input", and choose the correct signal depending on your using environment.
Please view this article to get more details:-
http://www.ehow.com/how_6041027_fix-snowy-screen-satellite-tv.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 07, 2011
  • 131 Answers
SOURCE: polaroid 32 inch. When picture has lots of blue,
Here is my older post. It is very likely these capacitors are failing on your set. There are dozens of symptoms for the 2 caps going bad. John
Hello; This set uses a very poor design. They are stacking two 450 volt cap to get a 900 volt rating needed in this circuit. This practice was used decades ago, but only with VERY high quality caps that are closely matched ALONG with stabilization resistors to keep the voltage drop even between the 2 caps. Polaroid uses cheap unmatched caps and even WORSE no stabilization resistors. Shame on you Polariod. At least one cap is bad, but they MUST both be replaced with high quality MATCHED caps. There is an 80% chance that these are your problem, but with NO WARANTY. If you have no way of soldering and testing, send it to me with $38 to cover parts, testing caps and return shipping. You must call first 207 998 5687 est. No weekend hours, but OK 9-5 est. Good luck, John
Posted on Jan 30, 2011
chesterpendi
  • 195 Answers
SOURCE: Screen loses brightness at irregular intervals, then eventually returns to normal brightness.
That problem is usually cause of bad inverter board..Your TV works fine and after an hour or minute it become dark or loss brightness until its totally black..
please replace the inverter board to fix your TV..
Posted on Dec 12, 2011
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
Aug 09, 2010 | Televison & Video
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Flickering picture when setting resolution to 1080P vs 1080I
This simply means that your TV isn't capable of handling a 1080 progressive input. This is why it is flickering. Change it back to 1080i(interlaced) and the only time you should ever see flicker is in a still menu. But even then it should be barely noticeable.
If your TV does support 1080progressive then you may want to change the scan frequency of the Yamaha receiver. Common ones are 24 frames/sec or 50/60 Hz. The amplifier should have an auto setting which will detect what the TV can display. The nice thing about HDMI is all that information is transmitted through the cable.
A version 2 or highspeed cable won't change the display at all.
Aug 11, 2009 | Samsung BD-P3600 Blu-Ray Player
Is my Protron 3250 1080P?
Unfortunately it is not compatible with 1080p, which tells you it can support blue ray. The highest compatible mode for your unit is 1080i. What this means is if you were to play a blue ray movie it will show it in 1080i resolution.
Aug 07, 2009 | Protron PLTV3250 32 in. LCD Television
I have sony bdp s300 tonight it began intermittent loss of HDMI signal. It comes and goes. Not the cable, just upgraded to the most recent software. No damage to the HDMI port. This one has me beat.
What brand of tv do you have?? Also what resolution does it display? 1080i, 720p,480i or 420p?some DVD's only use certain ones. U gotta make sure your TV can display the resolution from the DVD.
Jun 28, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
The display only goes between normal and zoom
Nov 14, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Apr 17, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
