Question about Gestetner - 6002 Digital Imaging System Copier
Gestetner 6002 Scan to Email not working
We recently aquired a facility that has a Gestetner 6002. Scan to email was working with the previous company's internal Exchange server.
We use a hosted email service and I need to setup authentication on the copier for SMTP and I can't find settings for that anywhere in the control panel on the copier or in the web interface. The ONLY settings for email I can find are the email address and the port setting.
Any idea where I can find or enable the SMTP authentication settings?
Thanks so much!
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the IP address of the copier?
    Do you know the IP address to your smtp server?
  • 37 Answers
SOURCE: Gestetner 6002?
you can down load a user manual for the machine at www.gestetner.co.za
Posted on Aug 14, 2008
  • 3 Answers
SOURCE: scan multiple pages to one file on gestetner 6002
I apologize but this is a little to tricky to explain here....
below are guides and information on how to set up and operate a Gestetner machine,
which will help you to sort out every thing..
This is the Gestetner Site to download manuals, user guides..
http://www.gestetnerusa.com/SupportDocumentation.html?OpenForm&zone=ZIDTDIE-54FRT7GE51&NavExpand=0
This is the Scanning Guide
http://www.gestetnerusa.com/manuals/savin/SavGestOpManuals.nsf/(All)/GX60027502ScannerReferenceScannerReference.html/$file/Scanner%20Reference.pdf
Posted on Oct 27, 2008
  • 126 Answers
SOURCE: Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
Posted on Jan 14, 2009
  • 86 Answers
SOURCE: GESTETNER DSM627 COPIER, SCANNER, FAX
The basic scanning method is to use the Twain driver, found in the printer driver disc.
Install it on your computer.
Put original on the exposure glass.
Open Word document, click insert, select from scanner or camera
and select your device scanner and click on insert.
Then you can save it and attach it to an email.
Hope I was helpful, please rate me, thanks.
Posted on Jan 17, 2009
  • 7 Answers
SOURCE: We need to know how to use the scanning facility on the R127 phot
Scan to folder is only possible by using Scan router software which you can download from gestetner site. Try to check the setting thru Web browser. Log in as an admin and see whether you can configure scan to email. you had to place so many settings to do this.
Posted on Apr 19, 2009
Hi we have just installed a gestetner asm645 (i think thats its name), and want to delete the old companies accounts as when we try to scan something it says it needs a "senders" account to scan...
can delete user accounts under system settings. Press the button marked 123(where you get your meter reading). under system settings go to administrator tools and address book managments. can delete user accounts and create new 1's. Or you can trun the user authentcation off. Then no code is needed.
Sender - under system settings go to file transfer. input your smtp and managers account email. When programing user in address book look for add as sender and input the email address. When emailing you can select sender and destination. If the user is not set up as a sender the list will be empty and you would not be able to select a sender. set up a user (email) that any one can use.
Jan 21, 2011 | Gestetner Copier
Need help scanning to email
first you need to ensure the scanner facility files have been down loaded to your computer .. if you go into the web monitor by http your ip address you should have the web monitor page up there you need to entr a user with your password and email address. then when you go to the scan option on your display of the copier you have hte option of scan to foldere or scan to email there is a manual email setting enter the email address and scan as normal. if you need more info give me a reply and I can email the details..
Dec 17, 2009 | Ricoh Aficio 250 Copier
Apr 16, 2009 | Gestetner Office Equipment & Supplies
Scan multiple pages to one file on gestetner 6002
Oct 27, 2008 | Gestetner Copier
Oct 09, 2008 | Gestetner - DSm627 Digital Imaging System...
Gestetner 6002?
Jul 29, 2008 | Gestetner Copier
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
Dec 27, 2007 | Gestetner DSm618 All-In-One Printer
194 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
