Xerox 4150 workcenter says fuser module needs to warm up. This appears usually first thing in morning. I have to power off then on to stop this from showing on the screen. also, it wont print until after I...
1. Switch off the machine, then switch on the machine.
2. Enter dC330 code 10-100 to heat the fuser to 180 degrees. Enter codes 10-200 (centre
thermistor) and 10-210 (front thermistor) to verify the condition of the thermistors.
3. Enter code 10-300 to check power supply unit 2. If necessary, install a new power supply
unit 2, PL 1.10 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.25
Item 9 are clean and in good contact with the fuser heat roller. Check the wiring to the
thermistors. Install new components as necessary, PL 10.25.
5. Check for continuity between the two pins on the fuser assembly connector, PL 10.25
Item 8.
NOTE: A cold fuser has a resistance of approximately 11.5 ohms (220V/240V) or 2 ohms
(110V).
6. Check that there is continuity through the fuser heater and across the over temperature
cut-out.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CON3, CON8 and
CON9 on Power Supply Unit 2. If necessary, install a new fuser connector, PL 4.15 Item
20.
8. Check the wiring between CON4 on Power Supply Unit 2 and CN7 on the Main PWB.
9. Install new components as necessary:
• Fuser assembly, PL 10.25 Item 1.
• HVPS, PL 1.10 Item 2.
10. Perform the OF5 Main PWB Check RAP.
4250/4260 Checkout
NOTE: The main PWB has test points. The location of the test points is shown on the Main
PWB PJ location illustration.
Refer to Wiring Diagram 17, Wiring Diagram 18 and Wiring Diagram 21. Perform the following:
unit 2, PL 1.15 Item 4.
4. Switch off the machine. Remove the fuser assembly. Check that the thermistors, PL 10.28
thermistor assembly. Check the wiring to the NC thermistor, PL 10.28 Item 19. Install new
components as necessary, PL 10.28.
5. Check for continuity between the three pins on the fuser assembly connector, PL 10.28
Item 8.
(110V).
6. Check that there is continuity through the fuser heat lamps and across the over temperature
cut-out. Install new components as necessary, PL 10.28.
7. Check the wiring between the fuser connector, PL 4.15 Item 20 and CN5 on the Main
PWB. If necessary, install a new fuser connector, PL 4.15 Item 20.
8. Check the wiring between CON1 on Power Supply Unit 2 and CN7 on the Main PWB.
• Fuser assembly, PL 10.28 Item 1.
• Power supply unit 2, PL 1.15 Item 4.
