Question about Cisco 7940 IP Phone
Cisco 7940 upgrade issues!
Hello! I have searched far and wide and cannot find a solution to my phone issue! Firstly, I brought the phone off ebay with the intention to use it with Sipgate (I understand I need SIP firmware to do that). When the phone arrived I plugged it in and connected it to my router hoping (probably quite naively!) that it would just work...this obviously wasn't the case. When the phone booted up the following showed: Configuing VLAN Configuing IP (for around .5 seconds) Protocol Application Invalid (O/A in the corner) It is now stuck on Protocol Invalid... I have done the hold # 123 etc. factory reset but am unsure a/ which firmware it had originally b/ which firmware it now has being reset I have installed tftp32d as a tftp server and have tried multiple firmware upgrades (SIP versions 2.0 through to 7.1 in hope the phone would pick at least 1 up!) and nothing happens, still the same scenario! I am really at a loss at what to do, no forums or Cisco documentation has helped...I am a relative novice! Please help me!
4 Suggested Answers
SOURCE: Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Posted on Jun 10, 2008
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
RPaterson
  • 48 Answers
SOURCE: Cisco 7911G definitely dead?
You are very close to fixing your problem. You will need the correct firmware and files; these are proprietary but you should be able to acquire them from your certified reseller. Alternatively, here at IdacomUSA, we have the proper firmware on hand, and can flash the phone for you to get it back to life. Call us at 1-800-903-9190 or visit us at http://idacomusa.com
Posted on Feb 11, 2010
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
Mar 04, 2009 | Cisco 7940 IP Phone
My Cisco ip Phone 7940 will not ring.
Give me your number, and i'll call you! Solved! =-D
Jan 27, 2009 | Cisco 7940 IP Phone
Cannot program Speed Dial
Try adding Cisco 7914 (time two) for additional (other) phone lines, or define caller group so phone call rings around.
Jan 17, 2009 | Cisco 7940 IP Phone
Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Mar 20, 2008 | Cisco 7940 IP Phone
My client has Cisco 7940 IP phones and wants assistance with feature programming
This phone can be access through a menu/ setting buttons.
Useful link on how to navigate through the phone:
http://www.cisco.com/warp/public/779/largeent/avvid/products/7940/7940_topic3.htm
I think the main problem is to determine the intergrated router or Call manager configuration
You can also connect on switch and type:show cpd neighbor This will show the physical port connections
Nov 27, 2007 | Cisco 7940 IP Phone
Netgear fs726tp and cisco phones
that the 7940 and 60
phones from Cisco do not support the IEEE 802.3af Power Over Ethernet
standard
they would work if you
simply reversed the polarity of 2 of the pairs of wire. i.e
by swapping 4 with 7, and 5 with 8 you could use a standard
POE injector to power the phone.
if you have a crimp tool and some cable laying around, you can give it
a whirl and it works. If you aren't familiar with making cable,
don't try this
Basically, you just wire one side of the cable as standard 568b
and then reverse 4 and 7, and 5 and 8 on the other side. Then,
simply plug your Cisco into a standard POE injector and Your phone works.
Nov 16, 2007 | NetGear ProSafe FS726TP Smart Switch...
Testing a Cisco 7940G phone
Heidi the only way you can test this telephone will be on a network that has cisco callmanager software installed.
Oct 18, 2007 | Cisco 7940 IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
