Question about Whirlpool LER5636P Electric Dryer
Whirlpool 9800 won't heat. I checked the element and is okay. ???
    President:
  • Whirlpool Master
  • 2,651 Answers
You checked it with a meter ofr continuity?? if so, then check hte littl white "fuse"(locasted directly in the middle of back of machine) and both of hte thermostat on the top and bottom of the heater assy. thay should all have perfect continuity
Posted on Jan 27, 2009
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
Bosch SGVE53E13GB Integrated dishwasher- cycles but won't finish
The heating element in the bottom of the unit may be burned out. With an ohm meter, check to see if there is any resistance with power removed and terminals of heating element exposed. If it measures about 1 or 2 ohms, it is okay. Anything more than about 200 ohms means there is likely a break in the element., If it is okay, then check the wiring to the heating element.
Oct 28, 2012 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Whirlpool GEW9200L Electric Dryer won't heat up
The heating element can fail open. Curious that Whirlpool did not mention that possibility.
Jan 25, 2018 | Whirlpool GEW9200L Electric Dryer
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Whirlpool cabrio wed6200sw0 dryer runs, won't heat up. blows air, lint line is clear and hi limit thermostat and thermal cutoff okay (have continuity) at room temp
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Whirlpool WED6200S Electric Dryer
Dryer will not get hot. All the vents are clean.
Check for burnt out heating element and electrical connections to element and thermostats. If okay check all thermostats, operating and high limit, with an ohm meter. All must be in closed position. If element,thermostats,and electrical connections good then check timer.
Mar 21, 2010 | Whirlpool LER4634J Electric Dryer
I need to replace the heating element. How do I
LOOK FOR AN ELETRICAL AND PLUMING OUTLET IN THE LOCAL AREA AND BRING THE PART WITH YOU WHEN YOU GO FOR THE PART .
Nov 04, 2009 | Luhr Jensen Little Chief 9800
Dryer all is working but not heating
Hi!
First of all please check the thermal fuse. If it is out okay (by-passed or tested with an ohmmeter), then check the heating element. This can be checked by removing one of the wires on the heater and testing it with an ohmmeter. Or,removing the element and visually inspecting it.
Thanks
Rylee
Mar 18, 2009 | Whirlpool Dryers
Whirlpool 9800 dryer
hII check cut on and off fuzes and timer also..Good luck..But always remenber you need 220 volts of current to turn on heating element so check too see if you have 22o volts.check breaker also is on...34c1d51.jpg
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
