Question about Intel Desktop Board D865GLC (MBIND865GLC) Motherboard
Audeo port not work
We have connect speaker with audio port but speaker don't sound. we have already instal driver and interface
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intel Master
  • 2,226 Answers
Check in setting control panel under sound
Posted on May 25, 2014
Dipu007
  • 2110 Answers
SOURCE: NO SOUND FOR D865GVHZ
Check the connection to speaker...
Posted on Dec 10, 2008
SOURCE: audio driver problem
HI my speaker not working after instaling windows xp os mother board name is 865ghavh my email id ravikumarts1@gmail.com pls sugeust me.
Posted on Jan 17, 2009
  • 113 Answers
SOURCE: audio problem
first of all check sound setings in windows.
take help from below link. http://www.fixya.com/support/t1720012-audio_problem
contact me if problem persists.
Good Luck!
neo
Posted on Feb 27, 2009
blubaustin
  • 242 Answers
SOURCE: Realtek HD Audio Driver Installation
It has a autodetection for when jacks are plugged into the audio port. Maybe the connection isn't just perfect, or there is corrosion/debree on it causing it not to make perfect contact. If that isn't it it may be the wrong driver.
Posted on Jul 28, 2009
fixyathing
  • 341 Answers
SOURCE: one of intel mother board was not working I think
check if you got a sound driver device conflict, you might need to get the correct sound driver for your OS
Posted on Aug 18, 2009
Audioport doesn't work
Hello download the sound driver here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=6816&lang=eng&OSVersion=Windows%20XP%20%20Professional*&DownloadType=
Here are the others:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GLC
The green outlet is for the speakers.
Uninstall the old driver before installing the new.
Make also sure the volumen is not turned down low or muted.
Here is no sound drivers for windows 7
Good luck
Jan 21, 2013 | Intel Desktop Board D865GLC (MBIND865GLC)...
I want the driver of frontech multimedia speaker model no.-1820
Speakers don't require drivers. Only your sound card. Connect as instructed. Usually the green 3.5mm port is the speaker input.
Oct 03, 2012 | Logitech LS21 3-Piece 2.1 Channel...
Where is the audio output on my aspire 4540
how did you connect external digital speakers when you cannot find the audio out port.that is the port where you connected.ok. try installing drivers for your system to get sound
Apr 07, 2012 | Acer Computers & Internet
I have no sound at all, not sure wot to do. says something about no audio devices are installed,
hello jenz8860, try open device manager (run type devmgmt.msc), if u find question mark on your audio device then u need to install audio driver.
to install audio driver use motherboard driver, insert to CDROM, right click the audio device on device manager then update driver. choose recommended option then click next and follow the instruction. your audio device will automatically installed. if it success installed then u need to restart your PC.
if there is no problem in device manager, high possibility it's on hardware problem, try to see cable connection between speaker and PC (use back panel connection, don't use front panel audio, this to make sure the connection is good), if it's ok then mostly problem came from your speaker. try to use another speaker.
hope this useful, regards.
Aug 26, 2011 | Audio Players & Recorders
I just reistalled Windows XP and my speakers do not work. They were working fine b4 I reinstalled
you will need to set up your sound card and drivers again if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 26, 2011 | Altec Lansing Multimedia Computer Speakers
I can't seed to get my speakers to work. I have UBL pro speakers.
1. Check the Audio icon on the task bar if muted. If yes Unmute Go to start > control panel > sound. and make sure that nothing is muted.
2. Sound Diagnosis refer this photo
3. Re install the audio drivers. LINK
4. If steps 1-3 don't work, then take your speaker to your friend's computer and see if it works there? if yes then something is wrong in your computer system, if no, then something is wrong in those devices.
Refer to this image below. From your speaker the 3.5mm jack should be plugged at back of I/O ports LINE OUT.
Thank you for posting hope this helps..
Jul 06, 2011 | Computers & Internet
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Sound problem
check for the audio driver in device manager if it is installed correctly...
also check for the speakers if they are connected in the correct port or not?
Apr 24, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
