Question about MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color
Mini Maglite LED not staying on
I have a Mini Maglite LED version that worked fine for a few days then started going out when tipped a little to shine in different direction or if bumped ever so lightly. This is aggravating! Some times cannot get it to turn on at all.
So bought another and after a few days use it has started same thing. Any idea what is going on??
  • 17 more comments
  • Anonymous Jan 30, 2009
    SAME THING
  • Anonymous Feb 08, 2009
    Exact same story....
    Same problem here....
  • Anonymous Feb 10, 2009
    My mini maglite led worked fine when I first got it, but after about two weeks if I move it or bump it it flashes on and off. I've tried replaceing the batteries, but that doesn't make a difference. What is up with this?!
  • JBMaglite Feb 20, 2009
    About a year ago I had the same problem. I sent it to Maglite for repair. I paid the shipping one way. The work order said that they had to redo a glue joint (?). It died not too long after the repair. Since then I have had about 10 of these Minimags with the same problem. I returned all of them to the store of purchase. Today I called Maglite warranty department and asked if they have been having any problems. They said no. I have been very careful not to drop the lights. For me, it appears that the lights fail after about 60 or so on/off cycles.
  • Anonymous Feb 20, 2009
    Same thing with three different lights
  • prn007 Mar 01, 2009
    mini mag led stays on for 10 to 15 seconds goes out then won't go back on. Like it's overheating then when it cools off it will go back on for 10 or 15 seconds. movement is not an issue as it does the same thing laying on the desk. I think it's a thermal issue and therefore a design issue . Mag ought to be taking care of it since they tout ruggedness and durability.
  • catbeller Mar 06, 2009
    Two LED mini-maglites, a 3 AA and a 2 AA model, both dead after many days of jiggling the swivel cap to get them to work at all.
  • Anonymous Mar 07, 2009
    I have had the same problem, and when I checked the batteries, the one furthest in had corroded and was no longer making contact when the light was turned on. I suspect that this had slowly been becoming a problem and the battery had been making poorer and poorer contact. Has anyone had a badly corroded battery in conjunction with this problem?
  • Anonymous Mar 10, 2009
    Same thing it willnot stay on and definitely will not spot or flood. What are we supposed to do this is a great light when it works.
  • Anonymous Mar 17, 2009
    I paid $20 for one of these flashlights and it was great when it worked,but now it will not stay on. I think it is something in the LED assembly (which I cannot figure out how to remove and examine)
  • satmil Mar 23, 2009
    I have bought my 3rd and last maglite. First 2 had the exact same problem. It worked at first, then you have to jiggle it and "maybe" it might come of for a few seconds. I kept buying replacements because MagLite is suppose to be a leader in flashlights. I have a $7 cheap-o bought at a random HW store and it works consistently.
  • Anonymous Mar 23, 2009
    Not myself, but I know of one person who exchanged  3 of them before giving up and getting an different kind. That was last summer(08). A while later you couldn't find that flashlight at homedepot. They pulled it off the shelves. And One other person who has only had it for a couple weeks.. There is something defective... and Maglite is lying if they say they don't know about it.... They would be informed on the returns.
    I was curious if the upgrade kit had the same problems.?
  • lesliegrate Apr 05, 2009
    same here. and i have cleaned all the contacts and made sure they connect by using clip leads and such. it does seem to be in the LED assembly or the LED itself.
  • Anonymous Apr 11, 2009
    Same problem, not sure thats a termal problem. Anyone tried the mag-lite in the fridge?
  • mithrill Apr 18, 2009
    Same as the rest, pulling the spring in the back out a bit seems to fix the problem. Longer is better. ( Replace the springs Maglite ? )
  • tuctuc May 02, 2009
    Garbage product. Cool appearance seem to be more important than reliable function with Maglite. I've also trashed two due to batteries becoming siezed in place. Stopped paying for the style and now have two cheepo flashlights that work great. Designing flashlights that work reliably is not rocket science but seems beyond the scope of this style-conscious company.
  • Jason Chan Apr 25, 2013
    It works! It works! Thanks for the link!
    It works!!! Thanks for the link!
I found this site because I too have a pile of these with that problem. I have had maglites since the time when they weren't available to the general public and have always liked them. These new LED lights are great for the light/size ratio and I was very sorry to see this product perform so poorly. After reading the comments here I went to the Maglite site and found some troubleshooting tips. Believe it or not I fixed the one in my hand and can't wait to go fix the others. They really need to spell out on the package how the LED unit works when the batteries get low. Apparantly when they do get low the unit won't dim, it will completely shut off. You turn it off and then back on again and it flashes on but then stays off. According to the troubleshooting there is a bit of electonics in this unit that will shut the unit off if the battery voltage falls below a certain threshold. This appears exactly like a poor contact problem. I thought I had try battery replacement on some of my units in the past. The toubleshooting section does also cover other possible issues and shows how to try to fix them - not a bad document. Here is the link - good luck - I hope they stay in business. I think they need to address this issue somehow or else they will silently loose their market share. http://www.maglite.com/pdf/CustServ/Mini%20Maglite%20LED%20FAQ5222007805552.pdf
Posted on Jul 30, 2009
  • 1 more comment
  • 97-Ram Jan 10, 2011
    I had the flickering problem too ! Drove me nuts also. I thought I would test the batteries, and WHALA they were low ! Put in new ones and works perfect ! Thanks to baubshep . 97-Ram.
  • JeffInDFW Jul 29, 2011
    I replaced all my old maglights with the new LED ones a year ago. 11 in all, and have had these exact problems with ALL of them. Was about to throw them all out and replace with another brand when I found THIS post just now. I followed the instructions on 4 of my LED mag lites and I can't believe it. They work now. What a load of ****. This saved me a LOT of money, so I am thankful (VERY!), but irked that I spent the last year fighting with my flashlites. I'm a lifelong Maglite owner, but this has ticked me off. Thanks for all who took time to post this info.
  • John Owens Nov 25, 2013
    I have one of these LED mini Maglites, I had really liked it, but recently it started to act really screwy, just like dirty contacts in the switch. I have been looking all over trying to find out how to get to the switch to clean the contacts, now I run onto this. It surely couldn't just be low batteries..could it? Replaced the batteries and it worked!!!! I'm sure glad I found this, the problem was much less than I suspected.
I just fixed mine!
Yes the design of the switch on this light is ****. I really like it's size and the amount of light it puts out. So, I would constantly torture myself by trying to use it with the flickering and twisting.
Finally, I resigned to the fact that it was junk and tore into it. I used a hairdryer to heat up the outside metal casing and then pushed on the metal tabs on either side of the bulb with a pair of needle nosed pliers to disassemble.
The assembly that comes is made up of three pieces consisting of the metal casing, a plastic insert, and a circuit board. The insert comes out by pressing the tabs on either side and pulling. Be careful to note how the insert came out because if you reassemble backwards, the light won't work.
The insert holds the circuit board. I used a marker to marke one side of the metal case and the corresponding side of the circuit board. OK, now the fix. The board has metal tabs on all for edges. The problem is with the top and bottom. They have a dimple that makes contact. I believe that over a brief period of usage the tab loses its springiness and the dimple doesn't make contact. The area it touches had wear marks, som I'm wondering if the divet keeps things from functioning.
Anyway, just bend the corneres of the top and bottom tabs out to increase the number of contact points. I bent the corners to about a 45 degree angle.
Reassemble by taking care to line up your marks(top and bottom matters too). Put the light back together and voila it should work.
I just did this, so I'm not sure how permanant the fix is, but it's been working well so far. I did take some pictures, if folks are interested. Post something here and I'll put up a link.
Posted on May 01, 2009
This is more of a workaround than solution. Unscrew both sides of your minimag. Take out the spring. Drop the spring down onto the batteries. Move the led around untill it turns on. Once you have found the optimal position screw the batt. end back. (Note: U must not move the spring or led just screw the end on tight!) It should now work properly. Just remember that next time you need to change your batts that the spring will fall out and you must repeat this process. Hopefully you do not need to change very often thats why you bought the more exspensive led model.
Posted on Apr 04, 2009
I tried the usual steps of cleaning the contacts and replacing the batteries and elongating the springs, and none of it worked. In solution #2, the poster describes removing the circuit board, which I did. I found that the inductor coil on the board had broken free and was unsoldered on one side. A little superglue and a quick dot of solder fixed me right up.
Posted on May 06, 2010
I definitely thank baubshep! This worked... I started pulling out the fingers as said in the maglite link provided by baubshep... Worked better for a few days and the trouble started again. Changing the batterys worked!! I just wast fouled by the fact that when the light was on although working erratically it was very bright! Thaaanks Baubshep :)
Posted on Mar 14, 2010
Yep, garbage. It had been 15 years since I bought on of these peices of **** and figured they had the flickering problem fixed by now. Not. Now they have changed it to make it more difficult to fix. Even the fixes were temporary back then. The main problem? Not enough contact area to carry the current to the bulb. I guess they are either afraid to spend an extra dime per unit to get it right or won't pay the royalties for a design that already works.
I'll never buy this brand again.
Posted on May 19, 2009
    Scholar:
  • 82 Answers
There is nothing wrong with the flashlight. Due to the high output LED bulb at 270 lumins the batteries drain very quickly. At first sign of flicker or shutdown i throw in some new batteries and im good for a few days. Im going to try switching to Li-ion, they are a little pricey but rechargeable and hopefully save me some cash in the long run.
Posted on Aug 20, 2015
    New Friend:
I put the pencil in a drill because the handheld method was not working. The pencil in the drill method work, but be careful it can destroy the pencil eraser real quick!
Posted on Sep 12, 2014
  • Paul Sep 12, 2014
    New Friend:
    Problem Solver:
  • 7 Answers
led light
Posted on Apr 08, 2013
    New Friend:
I took a piece of aluminum foil, folded it several times to give it some thickness and inserted it into the flashlight before installing batteries. So far so good.
Posted on Feb 02, 2013
The flickering problem was driving me nuts...I read somewhere that there is something at the back end of the LED that the battery touches that wears out over time, so after I tried cleaning the contacts I decided something new needed to be tried. I took a pair of needle nosed plyers and a paperclip and wrapped the paperclip carefully around the plyers until I had a flat disk that looked like two back-to-back Ds with an extra loop around it (or I presume a Euro penny or dime might be the correct diameter, but I can't find any right now) and I dropped that in before replacing the batteries. I haven't had a single flicker since doing that. The coil should be about half the diameter of the battery. Note that putting the coil between the batteries does NOT work. You need to improve the contact point between the first battery and the back of the LED module.
Posted on Jun 02, 2012
My 3watt 3aa led minimag also started to have the same problem i think, what i did was bending out the two pieces of metal in the tail cap.
the screw is getting flat so i am going to send it to maglite for repair.
aniway im buiyng the xl50
Posted on Mar 04, 2012
Here's my simple solution:
1. Remove battery end and batteries
2. Remove spring
3. Clean as much corrosion as possible
4. Replace batteries
5. Drop in spring
6. Replace battery end
I just did this and the flashlight works every time. Only time will tell how long this solution lasts.
Posted on Jul 12, 2009
Greetings,
I'm on my fourth and final mini Maglite Led in less than eight months. The first three, and the current one as of last night, all had/have the same issue above. Mountain Equipment Co-op in Burlington, Ontario, has been great about straight exchanging this product, but I'm finished with it now (unless I give in to the temptation to try one_ton green's solution above). This light may be sexy, but it's definitely dysfunctional!
JM
Posted on Jun 26, 2009
Is there a mini Maglite Led pro that takes 1 AA battery
Not that I know of- they are usually 2 AAs. The 1 AAA keychain model was terrible in that the "turn to on" function was intermittent so I could never trust it. Tried WD40, sanding the contacts, etc. This was the old halogen version.
Sep 03, 2015 | MagLite Mini Pro LED Flashlight with...
Where do I send my Maglite for repair?
hello
the warranty details and the address are here Albert. Good choice in flashlights, but you may wish to look at LED units. The technology has moved on, and Cree LEDs are incredibly bright for the size. Some comapnies make LED modules for Maglight. I have one.
http://www.maglite.com/repaircenters.asp Repair Centers Mag Instrument Inc Manufacturer of the Maglite Flashlight
Jul 29, 2014 | Mag Instrument AAA Mini Maglite...
Maglite 2aa back cap won't come off
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
Feb 03, 2012 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
My AA Mini Maglite needed a new bulb, and I am upgrading with a 3 white LEDs and a tail cap switch ... but now nothing I try can get the torch to work. Can you possibly, help, please?
You've introduced two variables to your flashlight, and each needs to be tested independently. It's possible that one--or both--isn't working properly. It's equally possible that one or both of these replacement parts isn't perfectly meshing with the conductive areas of the maglite body, meaning that they're not completing the basic circuit needed to power the light.
The best way to test your tailcap switch is either to try it with another maglite or test its continuity with a multi-tester. With the tester, you should be able to toggle between readings of infinite resistance (switch off, no circuit) and little or no resistance (switch turned on). If you're stuck at infinite resistance, there's a problem with the switch.
You could test the LED insert by using test clips to touch power to the module to see whether it will light up.
My guess is that the components are probably good, but that somewhere along the line, there's a break in the basic circuit. My leading suspect would be the connection from the LED module to the negative (flashlight body) side. It could be that the module is slightly out of round and it's simply not making contact. It could be that the finish of the maglite is acting as an insulator. However, I would recommend deferring this analysis until you've confirmed that each component works fine.
Jul 12, 2011 | MagLite Rechargeable Flashlight System
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
Maglite LED. Light switch is intermittent. Have had the same issue with my 8 month old 2AA LED Maglite, don't have receipt and have tried finding a solution to get it fixed again. Lost my temper with it...
Unfortunately not, I've seen more and more of these coming back to the shop here with faults. Mostly they seem to be connection problems like yours.
Pity, MAG are excellent and have really tarnished their reputation with this LED gimmick. A lot of the customers who return their LED's to us take a traditional MAG as a replacement..
Sep 01, 2008 | Camping, Backpacking & Hiking
MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color Logo
18,725 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
David Black
David Black
Level 1 Expert
 steve
steve
Alec Oren Orris
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
