Question about Motorola Computers & Internet
Motorola sbvs220 surf board cable modem - Motorola Computers & Internet
3 Suggested Answers
dante777
  • 623 Answers
SOURCE: motorola sbvs220
Make sure that your router and computer are set to get their IP addresses via DHCP.
Either the router is not setup as DHCP server or your computer has a static IP address assigned which conflicts with the router settings.
Do you have cable or DSL service (in which case the router should be set to PPPoE)?
If you have cable service, just reset the router to factory default by pressing the reset button on the back for about 30 seconds.
Then go to your computer and
  1. Go to Control Panel -> Network Connections.
  2. Right-click your Local Area Connection and choose Properties.
  3. Scroll down and double click on Internet Protocol (TCP/IP).
  4. Make sure that all settings are set to Obtain ...automatically.
Click OK two times (the second time takes a little bit longer, because the settings are applied.
If you have any more questions or need help with the settings, just come back here and leave a comment - I'm happy to help.
Posted on May 30, 2009
Tom Marvolo
  • 708 Answers
SOURCE: USB port on Motorola modem SB5120 is more of a
THIS ROUTER SUPPORTS CAT 5 CABLE
So you will need a modem that supports CAT 5
Regards
TOM
Posted on Jan 08, 2011
How can i get belkin n300 to recognize motorola SB6141?
Well kindly reset the belkin N300, try connect, most probably will get connected....By the by, which mean are you going to connect both? is through lan cable or wifi?
Jul 26, 2014 | Belkin Surf N300 Wireless Router...
Sb5120
1.screw the cable line into the (F-connector)port in the back of the modem just like a tv does.2.then use the RJ-45 lan cable supplied with the modem,plug it into the RJ-45 port in the back of the modem.3.then plug the other end of the cable into the computers RJ-45 port.4.then power on the modem by pluging it in,and letting it boot and detect the internet signal and all lights are on and in working order.then start surfing.The only time you will need the install cd is if you need to use the usb hook up on the modem.
Jan 31, 2012 | Arris SURFboard SB5120 Modem
I cant get my motorola sb5101 surf board cable modem to connect to a belkin g wireless router. the light on the belkin flashes orange when i try to connect it to the modem but no internet connection
I have a similar problem. The common denominator seems to be the SB5101. I have a brand new Belkin Surf 300N, same issue. The modem will not give DHCP to the router. I can connect fine via ethernet to the modem directly.
This modem seems to be a dinosaur.
May 21, 2010 | Arris SURFboard SB5101 Cable Modem
Problems with Motorola Surf SB5100
Have you tried unplugging the modem's power cord for at least a couple of minutes? If that doesn't work, have you called your ISP? The problem could be anything from a billing issue to an outage in your area, to a modem that needs to be replaced. Your internet service provider would be the best place to (try to) find help.
Dec 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Keep getting cannot connect to primary dns server
you need to call the cable company tell them your ip lease is cycling every 15 minutes, it is a node conflict, they can fix it on their end. if the cable modem is a hacked one, then you just need to clone a new MAC yours is not valid anymore. if not a hacked one, call tech support. good luck!
Sep 28, 2009 | Arris SURFboard SB5101 Cable Modem
Motorola sbvs220
May 29, 2009 | Motorola Computers & Internet
ENTERNET CONNECTIONS FOR PS-3 80GB
if you want to be able to play your ps3 downstairs with your modem upstairs, you might consider buying a Wireless Router that has Wireless G , for your PS3.
This will allow you to access your Internet all around your house without wires. I suggest looking for one that features MIMO or range plus max, or anything else that increases your signal range since there is a fair amount of distance involved.
The alternative is relocating your modem downstairs and hooking it up to the PS3. BUT your computer wont have Internet.
Aug 02, 2008 | Sony Playstation 3 (PS3) Console
Router as cable modem
This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast). Note: Please configure the router with the computer that was last connected directly to the cable modem. Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart. Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons. Setup Static Cable Connection Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. Note: If you do not know your settings, you must contact your ISP. Step 3: Click on Save and Restart. Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Power cycle the cable modem and router. # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Computers & Internet Logo
59 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
