Question about Sewing Machines
Static electricity in man-made fibres
How can it be removed?
  • Sewing Machines Master
  • 7,365 Answers
You might try putting it in the dryer on air fluff with a dyer fabric
softner sheet and see if that help the static cling
Posted on Jan 21, 2013
568 jones gives elect shock put bear feet feet on pedals no elect
Rehman, are you wearing wool socks and getting static shocks, ensure your cable(wire) is in good undamaged condition or replace.
press the helpful button and follow me for more tips
Feb 10, 2016 | Sewing Machines
Only sews in reverse
1. Remove the top and clean out old grease. To remove the top you may have to remove small screw covers. Also, many have snaps as well. Cleaning with carburetor cleaner and a qtip works very well.
2. With the hand wheel turn both directions and see if there are any sticking parts. You may have to force them free very carefully.
3. Put new sewing machine oil on the moving parts, etc. (Not plastic parts) Triflow should be used for plastic. You can get this on the internet.
4. Once you have it oiled, unstuck, etc put back together.
5. The same thing can be done on the bottom of the machine.
WARNING: DON'T TOUCH THE CIRCUIT BOARD AND STAY AWAY FROM IT. STATIC ELECTRICITY CAN RUIN IT.
Mar 25, 2015 | Sewing Machines
Power problems janome e300
I'M NOT SURE BUT IT IS POSSIBLE THAT YOU USED YOUR STATIC TO DESTROY YOUR CARD. IT WILL NEED TO BE CHECKED BY REPLACING IT WITH ANOTHER ONE W/O KILLING IT WITH STATIC.
Jan 10, 2015 | Janome Sewing Machines
Do you need to ol this machine
the manual will probably make no reference to oiling this machine but will recommend cleaning out the bobbin holder with a little brush regularly and getting it serviced by a tech annually. These newer machines have an oiling wick under the bobbin and nylon gears so regular oiling is not so critical. My tech told me that I could still oil into the wick occassionally which I do between services. Certainly if it is sounding noisier than normal then a single drop of quality clear Sewing Machine oil into the middle of the bobbin holder under where the bobbin sits, won't hurt it. The brushing out to remove fibres, threads and dust is important to keep the race area clean so the lubrication can work.
Sep 04, 2011 | Elna 7200 Computerized Sewing Machine
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
What is the need size, I broke my needle
the needle series is 130/705H the size depends on the fabric as a rule of thumb 80/12 for cotton 70/10 for silk 100/16 denim needles for heavy woven etc also the needles are available in stretch, leather, sharps (for micro fibre) etc.
Apr 24, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Electric leakage
It won't be electric leakage because it will blow the inline fuse, it is probably static that you are building up, touch something else metal before you use the machine
Dec 30, 2009 | Singer Quantum 9940 Computerized Sewing...
Am trying to change from light weight knit fabric on machine to light weight woven.push screen and it won't change . designer viking 1
It sounds like the screen has lost calibration. If you can get into "set" touch more until you see color touch screen adjust, then click on it. Click in the middle crosshairs next to the one, it should make a "click" and change colors, after that, do it to the crosshair next to the 2. touch "save". If you can't get the crosshairs to respond to your touchtry cleaning the entire machine and the screen with a static remover spray (NEVER SPRAY SCREEN DIRECTLY) spray your clean cotton cloth( eyeglass rag is awesome here) and wipe the machine down, then try again until successful. The company reccommends using a touch stylus in place of your finger to eliminate the transfer of static electricity to your machine
Hope this helps.
Kent
Mar 21, 2009 | Husqvarna Viking 1
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
