Question about Candy Washing Machines
Hi I have a Candy Alise 1400 washer dryer, it is 13 months old and it won't fill up with water, when you select a cycle and press start the lights come on and the door locks but that's it we c
Please note that if you leave the machine switched on at first it will display that there is 90 mins remaining and it will go down through the minutes in normal time till it gets to 15 mins and it sticks there but absolutely nothing else happens ie the drum does not move at all
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
  • 1214 Answers
SOURCE: machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Posted on Jan 29, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
KevinWhite
  • 1902 Answers
SOURCE: my candy alise washer dryer
Hello & Welcome to FixYa
The problem is with the door lock-switch assembly not working, the unit detects that the door is not closed/locked and so will stop in middle of cycle. Please get back to me if you have any other questions.
Kevin
Posted on Jan 09, 2011
caroldon
  • 17130 Answers
SOURCE: Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Posted on Nov 11, 2011
Hi, My Candy washer/dryer has stopped working. I get a light on either 1000 or 1400 spin, and a light on 15 minutes and nothing else. There is no water entering the machine.
you may have to take the top off in order to see if the water inlet valve is operating as that's where the water fills from
eric
Dec 29, 2017 | Candy Washing Machines
Candy Alise 1000es
Hello, Here is the location for the manual that you need. Candy Alise 1000 ES User Instructions
Aug 25, 2014 | Washing Machines
My washer/dryer isn't drying clothes
this is all i could find on the internet and that is the manual not sure if its going to be of any help to you but you could go to this link and download the manual and see if it does help you out.
i think its the first one on the page.
candy alise go4w464 washer dryer not drying clothes Google Search
Oct 31, 2017 | Candy Washing Machines
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I have the Candy Alise washer-dryer, It is 3 years old. The lock door sensor light is not coming on when the door is shut, the door seems to be shutting properly and making the click noise when it closes....
There is likely to be a problem with the 'door closed' sensor, unfortunately requiring a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 06, 2011 | Candy Washing Machines
Candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Jan 01, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
