Question about Kodak EasyShare Z650 Digital Camera
Problem with kodak z650 camera wont stay on
When I switch on the camera the orange light flashes then switches off screen stays blank. Odd times the orange light turns green and screen lights up but then after a few seconds it goes off again.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Posted on Jan 24, 2013
3 Suggested Answers
lock123
  • 6831 Answers
SOURCE: when i try to turn on my kodak MD41 the light goes
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
leepania
  • 1099 Answers
SOURCE: Kodak easyshare M893 IS will not stay on. The
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 23, 2009
Kodak z650 comes on fine but doesn't stay on-funny noise before it cuts off
Hello Donna, You camera is suffering from age, needs to be repaired or time to replace it. Sorry.
Nov 02, 2012 | Kodak EasyShare Z650 Digital Camera
I have a kodak easyshare z650 and i cannot format an 8gb sd card,
The Z650 is designed to work with SD cards. Your 8GB card is actually an SDHC (Secure Digital High Capacity) card. While an SDHC card will fit into an SD slot, it will not work properly. You'll have to stay with SD cards 2GB and smaller.
Aug 12, 2010 | Kodak EasyShare C330 Digital Camera
Sdhc 8g card won't format in a kodak z650
The Z650 uses SD cards. SDHC cards will not work in the camera. You have to stay with SD cards, 2GB and smaller.
Jun 14, 2010 | Kodak Cameras
Z650 won't stay on
Check and or replace the small button battery on the bottom of the cam. You can use a quarter to open the cap. remember which side of the battery is facing up when you open it, VERY important.
Aug 13, 2009 | Kodak EasyShare Z650 Digital Camera
My Kodak Z650 is showing lines in bright photos????
Hi!
The shutter doesn't work - the leafs may be stuck or the shutter cable is broken. You should contact your local Kodak service center.
Tom
Jul 25, 2009 | Kodak EasyShare Z650 Digital Camera
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Camera will not turn on. As I rotate the selector switch the light flashes at each position. Even when I switch it to off the off light flashes on and off. The screen stays on but it is blank.
Hello, Did you try pressing the little silver button marked "EVP/LCD" it is located at the left of the view finder,This turns the screen on and off.
Hope this takes care of problem.
Feb 06, 2009 | Kodak EasyShare DX6490 Digital Camera
Eror e6100 flashing
error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Feb 02, 2009 | Sony Cyber-Shot DSC-P71 Digital Camera
Kodak EasyShare Z650 flash problem
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=z650+as+is&category0=
Or I have a flash circuit for 30.00 plus shipping of about 12.00 my contact info is at www.digitalcamrepair.com
Apr 26, 2008 | Kodak EasyShare Z650 Digital Camera
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Kodak EasyShare Z650 Digital Camera Logo
91 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
