Question about HP Color LaserJet 2840 All-in-One Printer/Copier/Scanner/Fax Q395
When I print there is a 45 degree fold over on top right
Prnting from tray 2. I get a 3 inch 45 degree fold on top right. there is printing on the fold over. also sometimes the image is a little skewed. thanks for helping
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Use blower or vacuum cleaner to clean the printer properly .most of the time its because of paper pieces stuck inside the printer. Ensure that no more foreign particle present inside the printer.
Hope this will solve your problem & please rate me if its helpful to you.
Posted on May 27, 2013
    Genius:
  • 1,669 Answers
Check out all the rollers for jammed pieces of paper and loose dust. Clean them off carefully with a little rubbing alcohol.
Posted on Jan 21, 2013
How does new paper go in
fold the paper about half inch down and feed in along fold
Mar 14, 2016 | Casio HR-100TM Two-Color Printing...
Tip
Rocket Grill - How to make Inexpensive bags - As low as 2 cents each
Many of us have Rocket Grills which we love, but the bags can be expensive, and it is a pain if you run out of them when you want to use the machine. Here is my solution which I have been using since the machine was originally released. They will hold fat and juice too.
First of all, you are going to need to get some parchment paper. I buy bulk 12 x 16 sheets from a supplier off eBay. (Remember the more you buy, the lower the price). In an emergency you can use a similar technique with Reynold's Parchment paper rolls from the store.
You Need
A. 12 x 16 Parchment Sheet/S
B. Stapler
C. Sharp Pencil or Pen
D. Table or Flat Surface
D. (My Optional Template)
Instructions
A. Take one sheet and fold it in half. so you have an 12 inch wide by 8 inch deep sheet. Crease the sheet by running your finger firmly over the fold.
B. Place the folded sheet on the table, so that the fold is at the bottom as you view it.
C. Now along the short open sides (left and right sides of the sheet), one at a time, fold both layers over as a flap about 1 and a half inches. Try and keep both of these folds to the top.
D. Using a stapler, Staple each side that you have just folded one inch from the top, and a quarter inch from the edge on each side.
E. Turn the parchment paper 90 degrees counter clockwise so that the sealed bottom faces to the right.
F. Take the bottom part of the flap that you created in section C, and fold it back at a 45 degree angle. You should end up having two equal size triangles.
G. Turn the paper back around so that the first fold (A) is at the bottom again.
H. Staple each fold that you just created, about a quarter inch from the top of where the folded edge is. (see picture)
I. Place three equal spaced staples in-between the two staples you just did in section H. You should now have 5 stales in one line, about an inch and a half from the bottom of the bag.
J. Pick up the bag, softly fold it in half in the opposite direction as of section A. Make a tiny crease in the top (Open section). This is so we can find the center of the bag.
K. Place the crease over two of your fingers, and gently push the Pencil or Pen through the crease about 3/4 of an inch from the top. Do not rip the bag) This will be used hold the bag in the grill. (I have cooked 1lb steaks in the grill, and the hole holds the weight fine. Be gentle though)
Comments
A. I know that it is possible for the staples to lightly scratch the grill. However the Grill pads are not designed to come into direct contact with food anyway, and will not damage the grill
B. Some people may wonder about using staples near food. If you use new staples from a clean box you will have no problem. The heat from the grill will sanitize any impurities that may be on them. Also not that it is highly unlikely that your food will ever touch the staples.
C. The pouch at the bottom will hold fat and juice, but depending on the quality of the paper you buy will determine how well the bag holds up. It is possible for the juice/fat to weep through the staple holes, but thats why you have a drip tray.
Thats all folks. Message me if you have any questions.2bda07b.jpg39f5fe9.jpgb6d7936.jpg7040cb1.jpga957872.jpgcbfcbde.jpg
on Apr 17, 2010 | Kitchen Appliances - Others
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
How do i align head on printer
Hi Good day!! To Align read this
1. Raise the input tray, which you may fold over the top for compact storage. Lower the output tray at the bottom.
2. Slide the "paper-width guide" on the input tray to the left. This is the small, adjustable tab situated where you will place the stack of paper.
3. Load a small stack of paper into the input tray. Make sure short side is forward and the print side is up. For some paper, it makes no difference which side is up. Slide the stack down until it stops.
4. Slide the paper-width guide to the right, snug up against the stack of paper to ensure proper alignment.
Method 2:
1. click start
2. click printer and faxes
3. right click your installed printer and then properties
4. click printing preferences
5. click maintenance tab
there you should see alignment option click it
Thank you for using FixYa
Nov 19, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Part of my copy will not print. The top 2 inches
make sure the paper is in the right cassetts or you could have a problem whih the reigesation settings.
May 01, 2010 | Ricoh Aficio 1035 Copier
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Epson artisan 800 wont print to a transparency
OK so i tricked my 810 into printing on a transparency. NOT that I recommend doing this ... but .... I took four pieces of clear tape and taped the top (where it goes into the printer) and on each side about three inches from the top.
Then I put it in the tray with the transparency on the bottom of the paper -- since it brings it up thru the printer and flips it over, it prints right onto the transparency !!!
It didn't like it the first time, since I just folded over the tape on the end that gets sucked into the printer first. Hence the added stabilizers on each side.
Feb 15, 2009 | Office Equipment & Supplies
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Open Questions:
HP Color LaserJet 2840 All-in-One Printer/Copier/Scanner/Fax Q395 Logo
27 people viewed this question
Seeker5211
Seeker5211
