Question about Siemens Washing Machines
F2 fault its coming up f2
    Genius:
  • 1,669 Answers
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair.
Posted on Jan 21, 2013
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Dual dishdraw bottom Ok, top one wont start cycle,F2 comes up
Try swapping the motor rotors between the two drawers and see if the fault changes drawers, also check for anything stuck under the motors or and damage to the plastic of them. cheers
Apr 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 code on GE selfcleaning oven
The F2 fault code generally means the Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor Might want to check the oven sensor for high resistance. Get a ohm reading of the oven sensor at room temperature and tell me what this reading is.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | GE Ovens
Fault code f2-31 how do i clear
Need to know what machine it is you have
Dec 15, 2008 | Office Equipment & Supplies
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Washing Machines Logo
291 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
