Question about Brother MFC-8480DN All-In-One Laser Printer
SIZE MISMATCH WHEN FAX - Brother MFC-8480DN All-In-One Laser Printer
Paper size mismatch
1. Measure the paper you are using. A4 or Letter.
2. Set your printer driver default (on the computer) to the size in step 1
3. In each of the program like excel, word or adobe, remember to check page setup and make sure the size is that same as the paper size.
May 27, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Rx Fax info mismatch
Fax with Popfax with no more sending errors, busy signals, paper jam or faxes lost. So easy to setup Popfax service: no phone line installation or hardware purchasing required. Usually it takes only a few minutes to decide which package to choose and to subscribe to an internet fax service. The only things required are a device (Laptop, PC, Tablet or Smartphone) and an Internet connection. Try for free!
Jul 30, 2013 | Office Equipment & Supplies
Hi - I have a Xerox Workcentre 4250 Printer/Fax and keep getting error code 22-504 (Paper Properties Mismatch). The tray has the correct paper size ... what to do? All the pending jobs are idle ...
Check the print settings on the documents that are idle; they may be an off size rather than the standard and you may have to fake out the printer by "resetting" the paper size to the size of the print jobs; this sounds off but works in may cases. To reset the papersize, pull out the tray and put it back in, manually set the page to whatever it is calling for.
Please let me know if this is not clear,
Good Luck!
Oct 07, 2010 | Xerox WorkCentre M-24 Color Copier
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Mismatch paper
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00055507&cc=ca&lc=en&dlc=en&product=79499
Oct 19, 2007 | HP PSC 2210 All-In-One InkJet Printer
Brother MFC-8480DN All-In-One Laser Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
