Question about Epson Stylus Sx438w
I keep getting paper jam w-03 error message on my epson stylus
Error message is always there, but I'm sure there's no paper in there. What can I do? Thanks.
Inky
  • 691 Answers
SOURCE: Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
SOURCE: Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Posted on Jul 29, 2009
TJ4722
  • 54 Answers
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
Posted on Dec 13, 2009
pineworks
  • 4041 Answers
SOURCE: epson PX700w paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 05, 2010
Tip
My epson cx5900 wont print anything. it takes paper in, the head moves by a few...
Two ways to reset your EPSON printer ink counter, ink cartridge, protection counter and more.
A. SSC Service Utility For EPSON Stylus Printers
This utility allows you to do many amazing things with your EPSON printers:
  • Work directly with CSIC in EPSON Stylus printers cartridges.
  • Reset or rewrite any chip using special add on device.
  • Freeze internal ink counters.
  • Reset internal ink counters even with empty cartridges.
  • Separate cleaning of color and black heads for all EPSON ink jet printers, powerful cleaning mode.
  • Hot swapping of cartridges supported.
  • Resetting of protection counter (even then it is already full).
  • More then 100 different EPSON printers supported.
This program helps people with high printing demands to save money (program works with both black and color cartridges). The software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Click here for the SSC Service Utility for EPSON Stylus Printers
B. Using the EPSON Ink Pad Reset Utility
"Parts Inside Your Printer Has Reached The End Of Its Service Life"
Generally, this error message is caused by the malfunction of non user-replaceable parts within your printer. If your product is displaying the "End Of Life Service" message, please view and complete the required information from the link below to proceed.
Click here for the EPSON Ink Pad Reset Utility
on Jun 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus Photo R280 general error The printer has worked fine for years. All of a sudden 'general error' starts coming up. I understand this to be something is jammed in it. When I turn it on...
For Epson Stylus Photo R280 general error You may contact Epson Customer Service for any kind of help you require. You can also call on Epson printer support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5291 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Epson Stylus Photo R280 Series
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus Sx438w Logo
325 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
