Question about Kenmore 15864/15862 Top Load Washer
Kenmore 90 model 110.20912991 wont stop filling with water
Intermittent problem and have tried water level switch and clearing pressure hose to no avail. Works sometimes and then wont work for a few cycles. Can't leave the machine alone which kinda defeats the purpose of washing clothes at home..... Please help
On my kenmore 90, I found out that when putting back the cabinet, the hose that is connected to the load size selector was pinched... probably affecting the vacuum/pressure. Re-assembling the unit ensuring the unit was not longer pinched solved the problem.
Posted on Dec 09, 2011
  • 3 Answers
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Posted on Feb 09, 2009
Why is it displaying f2 code and will not drain?
The F2 fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
Clogged Drain Hose The drain hose on a Kenmore washer should remain free of obstructions so the water drains from the washtub. the drain hose behind the washer can impede the flow of water from the washer. A drain hose inserted more than 4 1/2 inches into a floor or wall standpipe drain system can cause the water to siphon back into the washtub.
Stuck Water-Level Pressure Switch Your Kenmore washer uses a water-level pressure switch in the control panel to detect the level of water inside the washtub. You can find the pressure switch behind the control panel in top-load models or attached to the inside wall of front-load models. The round switch is approximately 3 inches in diameter with a clear or black plastic tube connected to the bottom or side of the switch. The tube runs from the pressure switch to the exterior washtub. As the water fills the washtub, it changes the air pressure inside the tube and lets the switch know when the water has reached a predetermined level. A stuck contact on the pressure switch can stop the advancement of the wash cycle and keep the water from draining. A few taps on the top of the switch with a screwdriver handle can release the contact and fix the problem causing the F2 error code.
Jun 12, 2015 | Washing Machines
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Water wont stop filling on wash or rinse cycle , complete flood
take out the two screws that hold the top console down,flip the console up and on the left side you'll see the water level switch,make sure the clear hose is connected to it,if that's off the water will keep filling into the washer,if it is on take it off and blow gently into the pressure switch or the water level switch and listen for a clicking sound,if it doesn't click you could have a bad water level switch,next,unplug the washer,disconnect the lid switch harness and with a screw driver pop the two metal clips holding the back panel to the top of frame,pull the frame backwards to you and remove the frame off of washer,have someone blow into the clear line and check for any pin holes in the clear line or see if it popped off the bottom plastic piece that it goes to.if it looks ok change out the pressure switch but if there's a hole in the clear line that switch won't work it can't hold pressure and the water will just keep filling up the washer and won't stop like it's doing now,send the model number and i'll look up your part for you,or call your parts store and give them the model number and order the pressure switch or water level switch,it's the same thing,let me know what you find
Jul 13, 2010 | Kenmore 22422 Top Load Washer
Washer overfills, dosen't stop filling even after I cut washer off
bad water level switch or the clear plastic hose has a hole in it or popped off the water level switch or the pressure switch same thing.the switch works by pressure,if there's a hole in it or the line feel off there's no pressure and the switch keeps calling for water,shut the water valve off
Jul 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer keeps filling up with hot water
Hi
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Washing Machines
Kenmore 90 series- The water will not stop when I
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
Waher wont stop filling
If you had the unit apart, It is possible as well as Lumpy816 correct answers, for a surge in the pressure sensing line to stretch the tiny spring inside the level sensing body.
if replacing the hose does not rectify the problem
Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed
  6. test, adjust, test adjust.
  7. if no effect replace water level sensor body
May 22, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Mar 18, 2008 | Kenmore 24902 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
187 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
