Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Our dryer is running and the heat is coming out,but not turning
The dryer is not turning
  • Anonymous Jan 28, 2009
    belt is broken--so how do i replace it???? cannot find a manual anywhere online--have purchased a new belt but do not know how to put it on
  • Thespicybeef Mar 03, 2009
    I have a broken belt but do not know which panel to take off to access it. Mine is a Frigidaire top/bottom model #FLEB43RGS1
  • 135 Answers
Check for a broken belt. Hope this helps!
Posted on Jan 27, 2009
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
My Maytag dryer, MDG4658AWW, will turn on heat for one cycle then heat never comes on again. Also, when using permanent cycle the heat cycle comes on once, dryer continues to run then shuts down (cooling...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 25, 2011 | Dryers
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My Roper dryer quit running...it's heating but doesn't seem to come on or tumble.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
My dryer will run like normal but no heat will come out
check for a broken coil in the heating element. if it is ok, then you will need to check the thermostats mounted on the heater housing.
Oct 24, 2009 | Kenmore Dryers
Dryer does not heat up what should be done to fix it
There are 2 main causes for the dryer to not heat up. I assume it comes on and "runs", that is, the drum turns.. but no heat. If this is the case... check the fuses in the breaker box of the house. If it is a 220v. dryer it will need 2 fuses. Turn off main power to box before messing with any fuses. If you switch the 2 fuses around, see what the dryer does. If it fails to come on, then the fuse needs replaced and all should work. If there is no change, then the heating element might need replaced.
Oct 13, 2009 | Dryers
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
