Question about Konica Minolta DiMAGE Z5 Digital Camera
Unable to use memory card - Konica Minolta DiMAGE Z5 Digital Camera
Memory card
Are your phone and/or computer's card reader compatible with microSDHC cards or only with microSD cards?
May 02, 2013 | SanDisk 4GB microSD High Capacity Memory...
Unable to delete the files from memory card
take out ur memory card from mobile slot, make unlock ur memorycard adapter. its on the side of it. and insert it and try deleting folder.
Oct 18, 2012 | Motorola Mobility ROKR E6 Smartphone
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
Oct 19, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Unable to format the 2GB Memory card. Message occurs : Windows unable to complete the format.
A hidden application is disrupting your format process download "unlocker" software application from google, install it then right click on the memory card icon you find unlocker option double click n press unlock all after this try formating your memory card will work fine
Sep 20, 2010 | SanDisk 2GB microSD Memory Card
Mobile unable to read memory card and giving information that "memory card not formatted"and then sain"operation failed" pc is also unable to detect
Initially check whether the memory card is working fine.To ensure it use it in other mobiles.If the memory card is working fine means remove any password set in memory and check in your mobile.Then check the memory card in your mobile if the problem persists Memory card IC is the problem.
Most probably the problem is the memory card .
Jun 29, 2010 | Cell Phones
Unable to use card
Firstly, what size memory hard do you have? Is it an SDHC? Secondly, have you checked that the memory card isn't locked (there is a switch on the side of it). Has it worked with other memory cards?
May 07, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
Memory card locked
my memory card locked, i am unable to open my memory card, how can i open?
Mar 08, 2009 | Nokia 5200 Cellular Phone
My memory card files are unable to access
i want to put 1 gb memory card tomy n 72 is it possible and it is really working good or goes slow or it get hangs
Nov 12, 2008 | Nokia N72 Cellular Phone
Konica Minolta DiMAGE Z5 Digital Camera Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
