Question about Epson Artisan 810 AllInOne InkJet Printer
Using continuous ink system with no problems, but the black print head will no longer improve after cleaning. Can it be replaced?
  • Epson Master
  • 511 Answers
It's too expensive for replacing the head. Better buying new printer. Btw, try cleaning print head using manual procedure. Just browse here. It post many times.
Posted on Jan 21, 2013
5 Suggested Answers
  • 36 Answers
SOURCE: New black ink, but wont print any black ink
Epson Printers are terribly designed. There is a known issue with them related to clogged ink wells. Below the cartridge the ink dries in the well and makes the printer unusable. I have seen this many many times and will NEVER recommend an epson printer. Most of the time I will have people go out and buy a new printer only because of the fact that you will be paying 50-70/hr labor for someone to FIX/Clean your printer. If you want to try to clean it yourself go ahead. I have done it in the past with varying success because it is more trouble than its worth to remove the inkwells and clean them properly. Buy an HP printer. The difference is that the HP cartridge is what contacts the paper directly. There is no inkwell inbetween to get clogged. When you buy a new HP cartridge you will replace everything between the ink and the paper. Epson is just a poorly designed product. Hack
Posted on Jul 09, 2007
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
Posted on Apr 08, 2008
Tirzo
  • 94 Answers
SOURCE: black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
Posted on Jun 10, 2008
MerlinTech
  • 197 Answers
SOURCE: Black ink not printing...
same on a test page?
Posted on Jun 16, 2008
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
I have a 4 month old epson sx215 printer... everything was working fine two days ago and today i went to print some very important documents and my black ink wont work... the inks are all full, I have done...
you have two option,
1.you can do nozzle check and head clean , many time can repeat, there is any improvement you can continue the same process.it will work
2.change print head(better go for new printer,you should understand one thing, Epson print head along with printer so, you have to take printout at least every day one copy,if you are using HP inkjet printer,this kind of problem you can solve every easily, just change cartridge only,because hp cartridge along with print head not with printer.
Sep 25, 2017 | Epson Office Equipment & Supplies
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC-210 PRINTING IN BLACK INK POOR QUALITY BUT COLOURED INK FINE. USING INK MANAGEMENT TO CLEAN PRINTER NOT HELPING. HAVE TAKEN OUT AND REINSTALLED BLACK CARTRIDGE WITHOUT IMPROVEMENT. WHEN...
Try cleaning the black printer heads several times in a row, at least 5 times then print a black document with best quality setting.
Press the ink button, then down to select select cleaning and then press menu/set and menu/set again to select black.
Dec 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
  1. Double-click the HP Toolbox icon on the computer screen.
  2. Click the Printer Services tab.
  3. Click Clean the print cartridges and follow the directions on the screen.
If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
Jun 25, 2009 | HP DeskJet 882c InkJet Printer
Brand new Epson black ink cartridge won't print
Leaving an inkjet for two weeks with an empty cartridge is a definite way to get clogged printheads. Try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with anozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 25, 2009 | Epson Stylus Photo R300M InkJet Printer
Printing problems
What does the nozzle check pattern show? Missing lines no doubt. Using compatible inks? I bet you are.
Run the head cleaning routine four or five times then the nozzle check pattern again. If there is improvement keep cleaning it till it is right. If no improvement, check my previous posts about intensive head cleaning.
http://www.fixya.com/support/t138226-printer_not_printing
Nov 07, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Black Ink
Check in the printer utilities and make sure that it is not set to "draft" mode. Also may want to clean the area in the printer where the business end of the ink cartridge rests. Using the "head cleaning" feature doesn't always work completely. Go to your local pharmacy and ask the druggist for Lab Swabs. They are longer than a Q-Tip and only have cotton at one end. You will need the extra length to reach where you need to clean. Use isopropyl alcohol and gently rub the effected area. See if this helps. also may want to try uninstalling the printer drivers completely and reinstalling them. This works in a lot of cases. There are more problems with printers than any other component in a computer system.
May 05, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Artisan 810 AllInOne InkJet Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
