Question about HP D1660 InkJet Printer
What type of catridge does it use? - HP D1660 InkJet Printer
818b as black cartridge and 818 as color cartridge
Posted on Jan 27, 2014
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Nov 07, 2010 | Brother HL 5170DN Laser Printer
Printing on heavy paper gets a black vertical stripe
make sure all the catridges are fine and it is not getting leaked .if possible then remove the catridge and clean it and also when you give print command that time aslo you chosse paper type and size in printer properties option.
Jan 19, 2010 | Epson Stylus Photo 1290 InkJet Printer
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
My printer is epson fx 1170 it prints half word
this is due to catridge problem,
1.remove your catridge, use cleaner solvent to wet the head of catridge for 2mts and wipe it or clean it with tissue paper
2. check your catridge has ink or finish..
3. due to dry head and not enough of ink, this type of problem comes frequently
Jun 23, 2009 | HP Photosmart C6380 All-In-One InkJet...
Cartridge error
In this case make sure that the catridges are inserted in the right slot...... The Colour Catridge should go in the right side and the black Catridges should go on the left side.... Make sure the catridge which u are using on this printer is the right one.......... It should not be a refilled cartridge if it is it will not work because Lexmark printers are not designed to work with Refilled catridges it may damage ur Printer......... If everything here is fine just take out both the catridges...... Take a Dry Paper Towel........ Clean the copper contacts on the printer as well as the Catridges....... Unplug the Power Supply from the Printer............ Replug it in and if still it says catridge is missing then may be a problem with the catridges.............. Hope it Works..... Good Luck........
Jan 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
How do i refill a ink cartridge for a dell 720 printer
don't refill yourself just take the catridge to any of the computer repair shop just ask them to refill or else buy a new catridge of the same type
Jul 30, 2008 | Computers & Internet
On my hp psc 1315 all in one, the check print cartridge light is flashing. I followed the diagram and took out the little box inside on the left (the only side there was one) and put it back in on the...
power off the printer first,in the front side their is a door,open the door,power on the printer after a few minutes after the initilization,the catridge will stop in the middle,remove the both catridge ,clean the the back side (copper type dots) of both catridges and fix them again n check
regard
N
Jul 20, 2008 | HP Office Equipment & Supplies
Not printing
If the paper actually comes out, then tehre is a communication happening between the computer and the printer.
Chk for Catridge Settings / Ink in the catridge.
Hope this helps
- Ranjit
ranjit@supportminds.com
Nov 13, 2007 | Lexmark JetPrinter Z22 Color InkJet
HP D1660 InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
