Question about Dryers
What does it mean if the dryer is not turning, but the heat comes out and the dryer is "running" (what part needs to be replaced?)
  • 135 Answers
This would be a broken belt, most likely. Hope this helps!
Posted on Jan 27, 2009
Jeff, I have an Whirlpool Electric dryer Model #GEW9200LW1. The heat is not working eking. What should the thermistor read? Right now it's coming up 13.3 ohms.
what do u mean by thermistor? u mean moister sensor? thermal fuse?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Apr 11, 2015 | Whirlpool Dryers
No heat
make sure that the gas is turned on. if it is the next step is to check the fire chamber. it is a tube about 3in round. there is an igniter toward the front of the tube that when it calls for heat it glows bright red and then gas comes in the tube and it lights it up. if the igniter is not hot enough it will not light the gas. that means u need to replace the igniter.
Apr 15, 2014 | Kenmore HE5 7.0 cu. ft. Super Capacity Gas...
I have a samsung dryer dv218ae it runs but no heat can you help me
Your heater elements may be bad and need replacement. Is it an electric dryer? If so electric dryers run a dual breaker, this means 120 volts on one side of the breaker runs the motor, the other side of the breakers runs the heater coils. Its possible the heater side of the breaker has tripped. Try turning off the breaker for 20 seconds or so then reset. 220 volt breakers can trip on one side and not the other.
Sep 30, 2012 | Samsung DV218AEW Electric Dryer
My gas dryer is running but there is not any heat coming out to dry my clothes
When the dryer wont heat up and dry clothes it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Nov 24, 2010 | KitchenAid Dryers
I have a gas kenmore elite dryer model # 110.73032102 and it wont heat. It turns on and runs air comes out but its cool air only
There is a sensor you need to replace. There is a online store called Parts Select and you part# is PS344761 and it sells for 39.17 + tax and they will ship it to your home. Now because this is a heat sensor and it really has nothing to do about gas, so that means you can replace it if you think you are up to it
Jul 24, 2010 | Kenmore Dryers
Dryer not heating, but the heating element looks fine
If it is a 220V. dryer.. it needs 2 fuses. One runs the dryer motor and the other one runs the heating element. Check the main fuse box. Turn off main power before messing with any fuses. Look for 2 big fuses, probably in their own block. You can switch these 2 around and try the dryer again. If it does not come on, then the fuse is bad and needs replaced. If nothing is any different, then the element may need replaced.
Oct 13, 2009 | Roper Dryers
Dryer does not heat up what should be done to fix it
There are 2 main causes for the dryer to not heat up. I assume it comes on and "runs", that is, the drum turns.. but no heat. If this is the case... check the fuses in the breaker box of the house. If it is a 220v. dryer it will need 2 fuses. Turn off main power to box before messing with any fuses. If you switch the 2 fuses around, see what the dryer does. If it fails to come on, then the fuse needs replaced and all should work. If there is no change, then the heating element might need replaced.
Oct 13, 2009 | Dryers
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 series gas dryer and its not getting heat.  If I look at the igniter which is a carborundum igniter and I don't see...
Hi, You should first check the fuse. If the back comes off try this:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the rear panel does not come off, please get me model # and I can assist you further.
Please let me know if this helps you.
May 28, 2009 | Dryers
Gas Dryer does not run, light comes on in drum, everything else is dead.
do you mean it doesn't heat or does not run at all. i would check the door switch, if its not running at all. try opening the door and push the door switch closed by hand, if the light doesn't go out replace the switch
Nov 11, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
