Question about Hardware & Accessories
Instructions to wire a cooper light model number MS35 rain tight
  • 5,245 Answers
1) Copy following link for wiring diagram of 2-light outdoor motion sensor.
http://waterheatertimer.org/How-to-wire-switches.html#motion
2) Existing light fixture will have 2 wires: Connect wiring as shown on link above, then keep light switch turned ON.
Posted on Jan 22, 2013
What could cause engine misfire in heavy rain & carwash?
Ignition wiring system Error codes may identify more specifically. It could be as simple as a plug wire or distributor wire not installed tightly enough and water that normally would not enter the connection. Could be the Distributor cap is not on tight enough. and or the connection to the coil. Water usually affects the high voltage components. Double check all the spark wiring. I'd also take it to your favorite auto parts store for a code read.
Mar 21, 2015 | 2003 Mazda Tribute
Wiring instructions for Cooper TR7730 combination wiring device
Hi Dave,
Great description, but you never mentioned what you are
using the switch for. I can explain in detail, but I need to
know if the switch load is coming from the same cable or
an additional one.
Dec 18, 2013 | Cooper Wiring Devices Electrical Supplies
I have a cooper comb devces how do i wire i want switch to control the plug
The Cooper combo device requires neutral wire to energize the outlet.
To control outlet with switch, the Hot side of device must have break-away fin.
Remove break-away fin.
Connect jumper wire from switch load side to outlet Hot side.
Open following link for instructions with illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 20, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
For a price, expert works with you while you work on timer or any do-it-yourself project.
Sep 05, 2011 | Intermatic R8816P101C -...
I just purchased a Cooper Wiring Device 277W-box w/pilot light. The current switch in my home is next to another light switch which operates my hallway light. The other switch (the one I want to install...
Open following link for wiring diagram with written instructions.
Some of your wiring does not sound up to code.
1) Two differences between regular switch and cooper 277
-Different color screws: Regular switch has two brass screws, and either wire can connect to either screw. Cooper 277 has dark, brass, silver screws, and hot wire connects to dark screw, and wire to light connects to brass screw.
-Cooper needs neutral wire connected to silver screw, to power the indicator light.
2) Some of the wiring in your box does not sound up to code.
Bare ground wire should not be connected to black and white wires.
Electrician should check this out.
Probably the ground wire is being used as a Neutral. Bare ground wires and white neutral wires both connect to neutral busbar at main breaker box.
Aug 22, 2011 | Hardware & Accessories
Timer does not activate setting wheel. Stays on or off all the time.
1) If wheel is not turning, then replace motor
http://www.aplussupply.com/intermatic/timermotors.htm
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
There are numbers printed on clock motor. Also look inside door to see model number of timer. If you have a T101 or T103, T104 the T100 motor will work.
2) If manual override is not working, then replace whole timer.
3) You can buy same timer, and then swap insides
without replacing box. For example if you have T101R, the R stands for rain-tight box. Buy T101 and swap insides. Keep in mind T103 and T104 and T101 are not interchangeable due to wiring differences.
http:waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Sep 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I took a three gang face plate of now this switch is number 1 witch operates the hall number two switch operates the sitting room. number three operates the third light in the same room. but number three...
You need to determine where the power is coming into the box. That power line needs to be jumpered to each switch. The black of the lights will go to the other side of each switch. All neutral wires are tied together.
Bob Janelli
Oct 01, 2009 | Cooper Wiring Devices 3-gang Cooper Wall...
Wiring of Intermatic T8845pv
I believe the number you gave is fir the 14 day timer. Here is a link to the manual for it. Notice the not to use only one silver pin.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
May 31, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
900 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
