Question about Canon EOS Rebel XSi Digital Camera
I connected an external flash that evidentally wasn't compatable with the camera, now it won't pop up and says thereis an external flash connected even tho there is not.
I have checked the shoe and tried to use my nails and push the flash button to no avail.
    Novelist:
  • Canon Expert
  • 357 Answers
There is a switch in the hot shoe that detects whether or not an external flash is connected - the pin that operates the switch may be stuck down. Remove the spring piece on top of the hot shoe (I usually use an Exacto blade to loosen it and then slide it to the rear. Then remove the 4 screws and you can see the pin. If it is stuck down, moisten a Q-tip with water and rub it over the pin and blow with canned air to dry. The pin may pop back up. If not, or if the pin is damaged, you will have to remove the top cover and get to it from the bottom.
Posted on Jan 22, 2013
  • 25 Answers
SOURCE: I have a canon rebel
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Posted on Feb 18, 2009
t00nz
  • 4738 Answers
SOURCE: Lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2008
SOURCE: built-in flash does not fire off
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Posted on Oct 30, 2010
Tri3mast
  • 747 Answers
SOURCE: hello, I have a Canon
Okay there is a fix for this but it requires slightly removing the hot shoe. The camera thinks there is an accessory in the hot shoe therefor will not pop up. The fix for a qualified repair person is simple and it's fairly inexpensive however, that said if you don't know what you are doing then you could burn out the flash circuitry. Yes an external flash will work and give you much better performance then the internal flash, when getting a flash make sure it's an EX type to properly sync with the new TTL and I-TTL flash.
Posted on Jan 15, 2011
Testimonial: "ok, I will try the external flash. Thanks for your advice!"
Tri3mast
  • 747 Answers
SOURCE: I bought my new canon eos 60D..i put on external
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Posted on Jan 27, 2011
Gigaware 3 lsd touch hd
check to see if you still have the receipt, those are notorious for doing that i believe it is an internal wiring problem and exchange it
Jul 26, 2013 | Photography
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
Dec 25, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
My rebel t1i eos 500 built in flash won't pop up
Hi, I have to Canon Rebel t1i and I had the same problem (built in flash not working). I tried a number of remedies I found on forums etc but none worked. I then tried this. In the external flash housing is a metal sprung plate which surrounds the five circular pins (one big, four small at the rear). If you get a small straight headed screwdriver and lift the front of this plate and at the same time pull it back towards you it will come out altogether.
I then removed the four small screws being careful not to drop them and took off the mount for the external flash and then tried the flash it opened straight away. I then cleaned all the area of the mount and the two plates and replaced them all ensuring I fitted them exactly as before. I then checked the camera again and presto working fine. I hope this helps everyone with the problem.
Kevin (East riding of Yorkshire)
Aug 12, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
My flash won't flash on my 7d
Had the same problems several months ago. I will try a search the forum to find the nice labeled directions to solve the problem. This is not a major problem and can be fixed yourself.
http://photography-on-the.net/forum/...d+pop+up+flash
HID KITS.
Jun 01, 2012 | Canon EOS 7D Digital Camera
I purchased an external flash for my Nikkon D60 but I have not been able to make it work.How can I get the camarato recognize the flash and work properlly.
You didn't say what model flash you purchased so I can't say if it is compatible with your camera. You can't just buy any external flash and expect it to work with every camera.
Oct 18, 2011 | Nikon D60 Digital Camera
I was trying to take pictures in a cave that had some light but not a lot. The flash will pop up and the light bursts, but it will not take a picture. It just keeps focusing in and out and it won't...
It's probably too dark and the flash isn't powerful enough to assist the focus mechanism on far away objects (more than 10-15 feet).
If you will need to switch to manual focus and maybe manual exposure.
Sep 08, 2011 | Canon EOS Rebel K2 35mm SLR Camera
My Olympus vg120 switches on but the lens won't pop out. It makes a noise and tried to open but doesn't
Sounds like it has been dropped and is off track/set .As long as it wasn't broke electronic tech could fix it. Dont spend much tho cause they are around 75 bucks online now.
May 08, 2011 | Cameras
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in flash to pop out when needed.
I have tried turning the power off and on again. The problem persists.
Dec 19, 2010 | Canon EOS 60D Digital Camera
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon EOS Rebel XSi Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
