Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth failure When attempting to send or receive a file via bluetooth on the V3i an error message appears. I'm prompted to either accept or decline the incoming file, once I accept, the file starts to copy accross but only lasts a fraction of a second before saying "connection failed." What's going on?
  • Ryan Persaud
    Ryan Persaud Jan 07, 2008
    i have a motorola v3 and it say bluetooth power failed so i need help
  • badhan Feb 24, 2009
    bluetooth is not switch on
Hai
Posted on Feb 11, 2009
    Problem Solver:
  • 8 Answers
Pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time then start file copy
Posted on Jul 19, 2007
SOURCE:
How do i recieve songs through bluetooth from another phone?
Instructions
    • 1
      Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
    • 2
      Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
    • 3
      When prompted on the other device, give permission for the original device to access it.
    If transferring from phone to phone
    • 4
      Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
    • 5
      The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
    • 6
      When prompted on the phone receiving the file, accept it.
    If transferring from computer to phone
    • 7
      Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
    • 8
      Navigate to the place on your computer where your music file is kept in a separate window.
    • 9
      Drag the file from its original location to the correct folder on your phone.
    • 10
      Accept the file when prompted by your phone.
Tips & Warnings
  • Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Read more: How to Send Music to a Phone Via Bluetooth ' eHow.com http://www.ehow.com/how_4897391_send-music-phone-via-bluetooth.html#ixzz1xBSYWixA
Jun 08, 2012 | Sanyo SCP-2700 PINK Scratched Used Sprint...
How do I receive music via blue tooth from other phones
turn on bluetooth on both the devices and then in the sending phone go to that music file and go to option and then send option and then select via bluetooth the sending phone searches for other devices and list the phones that are available now select the name to which u should send the file and if you select send the other device will prompt you telling that you have a file and will ask whether to accept or reject once u select accept you will start receiving the file
Mar 10, 2011 | HTC Tattoo Cell Phone
How to download music from computer to cellphone?
There are 2 Methods
1 is via Bluetooth other option is using a USB data cable
via Bluetooth - Switch on BT on both PC and phone. - Click on BT icon in the phone and select send a file or you may send directly by selecting the file. - Accept the file receiving via phone.
Via USB cable
- Connect the cable. - Select Mass Storage from the phone , when prompted. - Copy files to the newly installed removable drive (Which is phone's memory)
Mar 07, 2011 | Nokia E63 Cell Phone
Cant pair phone with jabra bt2050 needs a passcode
How to pair and Send Music to a Phone Via Bluetooth
Bluetooth is a type of technology found in electronics that allows you to send and receive signals and files wirelessly. Most commonly used in cell phone headsets, many people also use Bluetooth to transfer data. There is no set protocol for all devices, so instructions for use vary from one device to another. Check out the following loose guidelines for sending music from one Bluetooth phone to another, or from a Bluetooth-enabled computer to phone.
Instructions
Tips & Warnings
Feb 17, 2011 | Jabra BT2050 Bluetooth Headset
How to transfer music contacts videos etc from LG cookie phone into I phone
Hi, there are different ways you can send data on phone, you can use a blue tooth device
Below is a step of how you an send Data like video, music etc from LG to iphone.
How to Send Data to a Phone Via Bluetooth
Instructions
Look for an option to browse the contents of the phone. Navigate to the data file or Multimedia folder on your phone.
Navigate to the place on your computer where your Data file is kept in a separate window.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your videos, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Hope that helped.
Good luck.
Feb 08, 2011 | Apple Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
Jun 21, 2009 | HTC Touch Diamond Smartphone
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
Motorola Mobility RAZR V3i Cellular Phone Logo
135 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
