Question about Microsoft Windows 7 Ultimate for PC
Cannot connect scanner to the computer - Microsoft Windows 7 Ultimate for PC
  • 89 Answers
Have you tried the add a device wizard?in win 7 drivers are usually automatically found
Posted on Jan 22, 2013
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
Tip
How to connect barcode scanner to your pc
In order for them to be useful, barcode scanners often have to be connected to computers. We will recall that in virtually all cases, the data which gives meaning to the barcodes they read is stored in databases, which are in turn hosted on computers. What the barcode scanners are meant to do, then, is to transmit the data they scan to the computer, with the computer checking that data against the database in order to assign meaning to it. In most cases, then, scanners without computers will tend to be quite useless. For a scanner to be useful, it has to be connected to the computer. And what we are interested in, for this discussion, is gaining an understanding of the ways through which barcode scanners connect to computers (at the simple, physical, external level).
As it turns out, there are four main ways through which barcode scanners connect to the computers which host the databases upon which they depend:
1. Serial port connection: this is where the scanner comes with a pin which you simply hook onto the serial port of your computer (like where you would hook an extra mouse), and thence connect the barcode scanner to computer. It was, arguably, the first method for connecting barcode scanners to computers to be developed. Its disadvantage is that it is not a plug and play approach. You have to go through quite a lengthy installation process for the barcode scanner, when you go this way. Furthermore, should the scanner 'hang' somewhere in the middle of a computing session, you don't have the option of just unplugging it and then plugging it in again to see whether it will work. Instead, you have to restart the whole machine again, and this can be very disruptive, for instance in the midst of a shopping checkout for a hurried customer. In this system, a scanner would also need specialized software to connect to various computers, meaning that there was no universality in scanner usage.
2. Keyboard wedge connection: this is a connection method where the barcode scanners are put in somewhere between the keyboard and the computer as a 'wedge.' It is something of an improvement on the serial port connection.
3. USB connection: this is what is to be found on most scanners, today. It is where you connect the scanner to the computer using any USB port. A scanner made in this way can, therefore, be used with pretty much any computer. Should it stall midcourse, you have the opportunity to just unplug it, and plug it again, to see if that solves the problem (which it often does). It is also convenient, because in this approach, connecting the scanner to the computer becomes as easy as connecting a USB flash disk to the machine.
4. Wireless connection: this is the emerging technology in ultra-modern scanners, where using systems such as Bluetooth, they are able to connect to the associated databases wirelessly.
on Oct 05, 2010 | Computers & Internet
Scanner to computer
Likely possible solutions
Install the driver of the scanner, If you have the setup or try and get it online
Also make sure that the scanner is connected the the computer properly by ensuring that there is a tight connection
Jun 14, 2012 | Ricoh Office Equipment & Supplies
My Epson 4180 scanner will not turn on. I tested the power supply and it is O.K. Frank
Ascertain that the computer recognizes scanner connection. For example, once ascertained the device connections to circuits been attained, trace the connections to the computer also from where programs should recognize the new feature required. Usually scanners turn on from computer programs. Once click activated would power on scanner ready to capture picture graph displays.
Feb 27, 2011 | Epson Perfection 4180 Photo Flatbed...
My computer (Toshiba Laptop) cant see connected scanner umax Astra 1220S. Pots are ok whith other connections.What could be the fault ?
Like me, so, you would need to go to the Adaptec.com website and find your computer or scanner and download for "Free", the latest SCSI Card driver, in order for you computer to recognise that you have a SCSI Card in your machine. Once you restart your machine, you will find that your scanner, should work perfectly.
Barbara Grey
Dec 27, 2009 | Umax Astra 1220S Flatbed Scanner
Scanner is not communicating with computer
Dear,
First of all, check All desire cable is connected to computer.
Power cable of Scanner and data cable (USB, COMM) connect to computer.
Install Driver of the Scanner,
if u not have a scanner driver, search on the Internet with the scanner model.
for further instruction
Contact with me.
Dec 11, 2009 | Symbol Office Equipment & Supplies
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Connecting the One Touch 8920 scanner to my Windows XP
Hello.
These problems seems to have a different solution every time and with differents addon devices.
However you might want to try this...
1. Restart the computer in safe mode and uninstall the scanner software from the control panel (add/remove programs or sofware)
2. Shut the computer down.
3. Unplug the scanner from the computer
3. Restart the computer
4 Install the software from the CD.
5. plug in the scanner to the computer and let windows detect the scanner.
6. (optional) restart again.
Good Luck.
Feb 10, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
SCANNER DOES NOT CONNECT WITH COMPUTER
What type of computer do you have? What is the operating system? Is this a new or used scanner? Ray Compuguy44
Jun 21, 2007 | Visioneer OneTouch 8600 Flatbed Scanner
Microsoft Windows 7 Ultimate for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
