Question about Jenn-Air Refrigerators
Jcd2389des refigerator not cold enough
Refrigerator not cold enough but freezer works
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
dididsaythat
  • 291 Answers
SOURCE: My refrigerator doesn't get cold enough
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Posted on Oct 26, 2007
kram26
  • 544 Answers
SOURCE: refrigerator not cooling...freezer is
HI,
you can try first this suggestion.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know,
thanks,
Posted on Mar 28, 2009
bestdarngood
  • 3037 Answers
SOURCE: Refrigerator works, freezer doesn't
The part that is usually the issue on this model is the defrost thermostat.
I usually test it for continuity while its frosty with an ohm meter. If you don't have an volt/ohm meter, you can get a cheap one at Radio Shack.
It clips on the top right side of your evaporator coil. It is part 23 on the diagram at this website http://content.searspartsdirect.com/lis_png/PLDM/P0070077-00003.png
Let me know if you need anything else
Benjamin
Posted on Apr 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: refrigerator and freezer not getting cold
Clean out the coils on the bottom, make sure the fan motr is turning below and remove the relay from the compressor. A lot of these relays are failing lately. If the relay sounds like a slt shaker inside it is toat. if it makes no sound at all it is bad. You should beable to feel the sliding start switch inside.
Posted on Jun 14, 2009
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
My unit is not cold enough refigerator or freezer. GE Model #: PS 123MGTA - Serial#: GL406451. I continue to push the adjust temp button to no avail. The freezer is set to 17 and the refigerator is set...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | GE Refrigerators
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Refigerator will not saty cold but freezer works
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
