Question about Cell Phones
My phone has stopped using the sd card
I must have somehow changed whatever. I have a 'B' with pointed curves and 2 tails behind at the top of the phone. Since this has appeared I can't use the camera etc. I have no instruction manual as the PDF Viewer is now empty, How do I reverse whatever I've done...Thank You
  • Sandy Thomson Jan 26, 2013
    Thank you everyone. My son solved my problem. He took the sim card out. This restarted the phone - now everything back to original. I guess like a computer needed defrag sort of. Yes, it's working. So again thank you for all your answers....Sandy
What phone do you have?
Posted on Jan 21, 2013
  • Sandy Thomson Jan 22, 2013
    HTC A3335 - bought from telstra but have had to change to vodafone due to local area reception. Can't download info to correct whatever I've stuffed up
  • 6 Answers
SOURCE: Hi I just bought a
there is a slot on the phone where the sd card will go. once you install it the phone will recognise the memory card and most models will ask if you want to make the card your default storage device. select yes and everything you store from that point on will be on the sd card.
Posted on Dec 11, 2008
SOURCE: LG Chocolate 3 won't read my Micro SD card full of MP3s!
Ok, I figured it out. Well, ok, maybe I didn't figure it out, but I did solve the problem -- by making sure everything on the SD card was backed up, and then reformatting it. Then I put all my MP3's back into the "my_music" folder on the card, and it all showed up on the phone -- finally!
SOURCE: FORGOTTEN MY SECURITY CODE 4 NOKIA 6230!
FORGOTTEN MY SECURITY CODE 4 NOKIA 6230! MY IMEI IS 356952/01/01184880/3
Posted on Jun 15, 2009
  • 132 Answers
SOURCE: instructions for using the cect i9 phone
hello,
I have uploaded your manual to rapidshare under following link: CectI9 Manual
You will need the Adobe Reader or some other program that handles PDF files.
Hope it helped.
Posted on Nov 18, 2009
Testimonial: "Excellent and fast response"
rajsun22
  • 73 Answers
SOURCE: hi, i m using LG
Sometime this occurs due to the format issue. Did you format the SDcard using Win32 or NTFS? those two are likely the culprits.
If not, it is time to replace the card.
Posted on Mar 04, 2011
My Moultrie M880 game camera is set to take 3 pictures, so once I place the SD card in turn on and I have in a area with no moving grass or limbs the camera will take pictures non stop. I will check i
Post subject: Re: M880 problem Solved .... icon_post_target.gifPosted: Tue May 27, 2014 3:48 pm icon_user_offline.gif
First of all, ONLY USE THE STANDARD SPEED SD CARD THAT MOULTRIE ADVISES.
Second, DO NOT TAKE THE CARD OUT & USE A READER WHILE LEAVING THE CAMERA MOUNTED (this will lock up the camera).
Third when using a brand new standard speed sd card, DO NOT FORMAT THE SD CARD IN ANYTHING OTHER THAN THE CAMERA.
One could clear the camera by reseating the battery (take the battery out & put it back in). The reset button (up inside) is not always necessary for this.
You probably got a different speed card to somehow work & the camera malfunctioned. Bear in mind the aforementioned advice.
Nov 29, 2014 | Moultrie Cameras
How can i unlock my Memory card password
Well it has a lot to do with the phone, the phone's OS, and the way you "locked" the SD Card. If you encrypted the card you are likely out of luck.
If it is only a password, you can recover it with a PC using a SD Card reader and a text editor.
1. Put the SD Card in the reader(use a micro SD to SD adapter if necessary)
2. Open your OS's file browser and locate the file with MMCSTORE in it's name and open it in notepad or whatever your OS has.
3. Profit!
The password is stored there or should be and readable.
Oct 09, 2014 | Cell Phones
Blackberry curve
use file explorer to move pictures (or whatever data files) around.
Apr 24, 2017 | Cell Phones
I tried putting tape over the tab on the ad card and it still shows write protect on the 3DS. I did put sd card in my computer and was able to copy a song on it so now I am thinking its a problem with
So on an SD CARD, which uses a MMC Interface, the WP# Signal is an actualy physical line, which should indicate to the host (the DS or whatever), that the device cannot be written to.. Furthermore, the spec indicates that when the line is active, the device should NOT allow writes to the device.
So, given you've flipped it to non-write protect..and the device says it is..there's a couple of possibilities:
1) The device is damaged, and not able to pickup the fact the pin (those gold pads on the back of the SD card..) are saying..no I'm no write protected... so,, you might try some compressed air in the slow and clean out junk... OR
2) The device is damaged,,and somehow things your device has that line (signal) pulled a certain way... saying its write-protected.. again.. clear it out w/air..or its possibly damaged.
3) The SD card itself MAY be damaged..and before blowing air, or using alcohol to clean contacts..etc.. before you get crazy with it..try a different card.. Maybe it when through something to damage it..it is tiny and fragile afterall...
4) If #3 doesn't work..and another device does the same thing.. try #1 and #2...post that...your device is broken :-(
Oct 19, 2012 | Video Game Consoles & Games
I try the show me and they ask for an sd card what is it?
Sir/Mam
I can't get the point what you really want it.
But regarding SD Card It's the Memory card that are commonly used in the Camera. And for hand-set is micro SD cardit's commonly used in cell-phone
Oct 04, 2012 | HTC Desire Cell Phone
Formating sd card
Good Day, To format your micro sd memory card, on the Home, press the Menu key then scroll to Options and click, then to Memory and click. Press the menu key and scroll to Format and click, then confirm it. That's all, so easy. Thanks for using Fixya.
Nov 02, 2011 | RIM BlackBerry Curve 8520 Smartphone
Okay, I couldn't find my BlackBerry phone charger for like four months, and when I got a new one I forgot the password. I only have TWO more chances to unlock it and I DON'T want to lose anything...
There is no chance you can get that picture or doing backup process unless your blackberry curve 8300 unlocked. That's the feature of RIM security system, try to remember your password and if you confident with that password then try to make your blackberry unlocked. Good luck and I hope you succeed.
Jul 21, 2011 | AT&T Blackberry Curve 8300 Smartphone
I bought a blackberry curve 9330 and it hasn't a sim card space !!!! i don't know what to do, and i bought in ebay!
It might be for Verizon if there is no sim card slot otherwise on blackberrys the sim will go behind the battery
Jun 30, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
W490 wont read memory card
Hi, sykko_one, I have the exact same phone and was experiencing the same problems. After about a year of using my phone and storing music, pictures, videos, etc. on my phone it would suddenly stop working. Sometimes it would work, and sometimes I wouldn't be able to save or read any data on the memory card. What I did to fix it was completely remove the memory card from the phone and used a micro sd Tinpec card reader, picture here. You want the one that supports micro sd. You can find them on ebay or amazon. Then connect your micro sd card to your pc with the adapter and right-click the removable drive (might be drive e: or f:) and choose format. Leave the default options and format the disk. Make sure you've selected the right disk. To verify this you can open the drive and look at the contents, it should have a folder called "moble." Go ahead and format the drive. Then use chkdsk.exe from the command line to check the disk for errors. Syntax will look like "chkdsk f: /f" or "chkdsk e: /f" (depending on the drive letter assigned to your sd card reader.)
If the format and chkdsk do not work. try just deleting all the information from the card and copying some pictures and music files to it. If these copy successfully then I would assume the problem is with the firmware on your phone. Take the phone to a t-Mobile store and see if they can't re-load the firmware. And don't worry about deleting any data from your sd card, it will not affect the phone in any way, it will just delete whatever pictures music files you have stored on the card. So be sure to back those up first before you do anything. Hope this helps. -Rogueelite
May 06, 2009 | Motorola Mobility Razor Behind-the-Head...
On 8110 blackberry phone how do i tranfer contacts from sd card
You can do this using the desktop mananger - by synchronising your new phone to your SD card - assuming you have a card reader.
If not does your SD card fit your new phone?
Apr 21, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
