Question about Car Audio & Video
Holes for sub power cable from battery to cabin
I have a w reg ford fiesta does anyone know where there is a hole for the power cable to go from the battery to the cabin so i can install my sub?
  • 20 Answers
Where th main harness goes into the cab there is a rubber gromet. Cut a **** in the gromet and sid through there be carful and donr cut the harness
Posted on Feb 28, 2013
5 Suggested Answers
  • 15 Answers
SOURCE: unlock stereo code needed ford
contact your local ford workshop and they should help you
Posted on Dec 29, 2008
MrScary66613
  • 1990 Answers
SOURCE: my twin jbl 12'' sub in a enclosure dont seem to be giving bass
Those 12's Need to be in a Ported Inclosure to release the Air that the Bass Produces. Use a 1 Inch Key Hole Bit and make 1 Hole at the Top Corner of Each Portion of the Box. Top Left and Top Right. Please Rate My Response! Thanks!
Posted on Feb 02, 2009
  • 4869 Answers
SOURCE: Need the code for my
The radio SERIAL NUMBER is required for a code Sometimes pressing buttons 6 & 1 together or 6 & 2will display your Serial Number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER foundon a label on the casing
It usually begins with M++++++ or V++++++
Posted on May 13, 2011
Daveatwhips
  • 492 Answers
SOURCE: disconnected battery to charge then
You can get the code from your local dealer. All you need if your VIN #. May cost a little but is well worth having the right one. Hope this helps
Posted on Aug 19, 2011
What is the best way to run wires from my battery to inside the cabin to wire in a power converter?
The best or more professional way to run the cables is to drill a hole thru the firewall. You need to use wire ties on the cables and route the cables along the factory wiring harness. Try to route to the shortest distance and use a rubber grommet where you have the hole drilled in the firewall. The grommet will keep the cable from getting damaged by the sharp edges of the hole that you drilled. Also the largest possible diameter cable is better because you will get more amperage to the power inverter. Hope this helps :)
Dec 20, 2010 | Ford Taurus Cars & Trucks
Where can i run a power wire for an amp in a '99 buick regal?
Power wire for an amp is usually ran from the battery through the firewall to the location of the amp. GM is pretty good about having a hole for running cables through the firewall. Check the size of the cable, and locate a hole where the cable will fit, then slide it through to the cabin of the car and run it where it needs to be. Ground wire is typically tied in to the chassis.
Very rarely will one have to drill a hole from firewall to the cabin if there isn't a pre drilled hole.
Sep 19, 2010 | Car Audio & Video
Hi I have a ford fiesta zetec 1.2 y reg when I
Battery Cables may need to Cleaned and put back on There not making Contack,OK...
Aug 02, 2010 | 2001 Ford F150 Styleside SuperCrew
Fiesta running lumpy
try running redex through the system then change the fuel filter to rule out a blocked line
May 19, 2009 | 2000 Ford Expedition
Need unlock code for Ford Fiesta Stereo
call the ford dealer and talk to the service desk they can give you the code
May 03, 2009 | Vehicle Parts & Accessories
I am scraping my M reg ford fiesta, radio is good
there should be a short section of wiring loom from the rear of the head unit to two connector blocks.These a usually universal from car to car, just take that from the fiesta and plug straight into peugot. Failing that you can buy them at most auto factors.
May 01, 2009 | Car Audio & Video
My twin jbl 12'' sub in a enclosure dont seem to be giving bass
Feb 02, 2009 | JBL GT412 Car Subwoofer
Can't locate the firewall hole on my 1996 audi a4 2.8L Manual.
In my 99, I ran it through the ECU's container. Open the hood -the ECU box is at the base of the windshield on the driver's side. Open the cover, unbolt the computer, and lift it to the side (you don't have to disconnect it, and I wouldn't). You'll be able to look down through the hole where the harness comes in, and you'll see your floormats. Run it up that way. There's a grommet on the ECU box that you can pop out and run the cable through to reach your battery.
Oct 26, 2008 | 1996 Audi A4
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
