Question about Kenmore 62602 Electric Dryer
Dryer wont run
My dryer was working fine yesterday and took a dry load out and went to put another in and turned it on the cycle I wanted and went to push the button and it wont run. the light is on and the door is shut tightly my fuses and circuits are fine in the house. I really dont know what to do!!!
  • Kenmore Master
  • 8,220 Answers
Remove the rear cover and replace the skinny white fuse mounted on the blower housing after you have cleaned out the lint from the dryer. (unless you like to keep buying and replacing them)
Posted on Jan 30, 2009
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
My Neptue dryer wont dry unless I run it more than one cycle. model no. mdg5500awq. all lights work and seems to run fine it just wont dry the cloths unless I run it at least twice and jeans are three or...
Turn dryer on and go outside to the vent and check for a good amount of air coming out. If you do not have a good amount of air coming out, take the exhaust tubes apart and clean.
Jun 07, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The dryer drum will not turn.
Could be belt gone if the drum is quite easy to turn by hand. Or motor in @worst
Apr 01, 2010 | GE Profile Harmony DPGT750EC Electric...
My Bosch Classixx washer dryer has stopped drying and the clothes come out steaming hot and steam escapes from the powder drawer during the drying cycle. I have had an engineer out and he says the airflow...
if you have a very large load of clothes in the machine on the dry cycle, what tends to happen is that the clothes are not flapping around in the drum loosely but they are going around the drum in a big mass, with the result that they just get very very hot and steam will escape out the soapbox draw. When this happens, heater unit that becomes overheated ant the thermostats will eventualy cut out resulting in cold air being circulated instead of hot. You will need to have them replaced again. when replaced, put on a drycycle with only a few garments in the machine and you will see a big difference in it perfomance. washer/dryers are not very effective on the drying cycles with a full washload.
if you need any more help, you may email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WVF 2402 Front Load...
The worked fine 2 days ago then went to use it
Hi there,  I'm not sure if you've had your dryer fixed yet, but it sounds like the heat exhanger (which is located on the lower right front side of your machine. To clean this, you must first disconnect the power cord from the wall. Next, you slowly remove this and clean it thoroughly with running water. After you wash it, let it dry completely - and then insert it back into the machine. It's a good idea to write down the steps you took in removing it, so when you put it back - it will make it easier. If it's not inserted right, your door won't close - so that's why it's important to jot down the steps when you removed it. Hopefully, this has been taken care of already. But if not, feel free to contact me. Also, it's a good practice to change the lint trap before or after each load. This machine is very sensitive to it, which is good - because it's protecting it and its longevity. Good Luck!
Jan 13, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore 62602 Electric Dryer Logo
117 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
