Question about Tablets & eReaders
Innotab water damage - Tablets & eReaders
How do i install on innotab 3s if i have not got a disk drive for installation disk is there another way thanks
go to this link : http://www.vtechkids.com/download/ you should be able to find a link to download the app for it3s there
Mar 06, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
My sons innotab 3s won't charge
try usiing just the charger without the rechargeable batts...if toy turns on with just that then prob maybe eiither the toy itself or you need new rechargeable batts
Feb 15, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
How can I gt my vetch innotab screen to work
is there any sound at all coming from the toy? if there"s no sound try pressing the power button down for 30 secs without any powersource...after that place batts back in and try turning it on. if it doesnt work you may want to call their hotline
Jan 07, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
My daughters pink vtech innotab 3s touch screen seems to be not working, she cant touch anything
Try recharging the batteries, or try using another powersource. if this does not resolve the issue then you may need to call their hotline
Mar 19, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Innotab 3s troubleshooting
Try to uncheck the checkbox indicating administrative account thay holds up to secure data..
Mar 15, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Troubleshooting innotab screen
have you tried calibrating the screen? You can do this by pressing the Home Button, question mark, and volume up button all at the same time. Turn the toy on without letting go of the other three buttons until you see the Touch Calibration Screen. If this does not help, then I suggest you call Vtech. Contach info is available at www.vtechkids.com if you no longer have the manual.
Jan 22, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Innotab 3s some items failed to load due to network congestion
Has this problem been resolved? If you still get this issue I suggest you call the Vtech hotline. Contact info can be found at www.vtechkids.com
Dec 25, 2013 | Vtech InnoTab 3S The Wi-Fi Learning App...
Can I use my iPad to download games into sons INNOTAB ( first version)
yes you can. Go to Downloads section on www.vtechkids.com. But in order to transfer the games into the toy, you need to connect it to a computer where Learning Lodge is installed.
Jan 19, 2013 | Vtech Tablets & eReaders
Tablets & eReaders Logo
111 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
