Question about Samsung Televison & Video
Samsung BN41-01799 Main Unit Board - Samsung Televison & Video
    Genius:
  • 1,003 Answers
Buy one from ebay.com just type in BN41-01799 on searchbar or get it at shopjimmy.com
Posted on Jan 21, 2013
How can I repair the back light on a Samsung UN46EH5300F TV? The only circuit boards in the unit appear to be a power-supply board, a main board (the TV tuner plus the HDMI inputs), and T-con board.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Jan 04, 2017 | Samsung UN46EH5300FXZA
After watching Telstra to unit attached the blue Samsung logo appears and the screen goes black. I can hear the show in the background. What is causing this and how do I fix it please?
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 20, 2016 | Samsung Televison & Video
Where is zsus board located
Samsung 50 Plasma Parts ' eBay
www.ebay.com/bhp/samsung-50-plasma-parts
eBayFind great deals on eBay for Samsung 50 Plasma Parts in TV Boards, Parts and ...Samsung 50" PN50C430 LJ92-01728A Plasma Y-Main YSUS Board Unit Motherboard.... Part Number: LJ92-01705C (Partial PBA number (705C) can be found on a ...Samsung HP-R5072 50" Plasma HDTV Main Board BN41-00632A ...
Samsung Buffer Board Test and repair Part 1 - YouTube
? 11:20
https://www.youtube.com/watch?v=5hVi5gd0aec
Oct 5, 2010 - Uploaded by z28r2fast4u
I checked two buffer boards and found 11 out of the 12 ic's bad.... my samsung, I post the video here, do you know how to test YMAIN and ZSUS ? .... Samsung PN50C450 with a bad Plasma Panel Shows how to replace the ...
Jan 18, 2016 | Samsung HP-R5072 50 in. Plasma HDTV
Where is fuse located...part #3601-001197
The part number you provided is invalid--Samsung parts start with DD such as the main board is listed. The main board part number is DD92-00033B. There is no fuse--I've scoured the exploded diagram and parts list--there is a leakage sensor located at the bottom of the unit, directly in the center of the bottom frame. If water is detected, the sensor tells the main board to shut down. The main board is located behind a cover at the base of the dishwasher below the door. You will have to remove the kick panel to access it. WARNING--that main board cover can be tricky to put back on. It's metal, has a relatively sharp edge, and if installed improperly, will cut into the wiring harness--and that will be a BIG oops! Make darn sure you route the wiring harness properly so the cover fits properly without pinching anything(ask me how I know this--and I'm a tech--it can happen to the most experienced person). BTW, did you have a power outage recently? Maybe 3-4 weeks prior to the problem. Outages are notorious for damaging circuit boards. If your unit is totally dead, you might have a blown main board--that's why I gave you the part number. The user interface board(touch panel) is DD92-00037A. The display board is DD92-00038A. I hope I helped you!
Sep 12, 2015 | Samsung DW80F800UWS 24" Stainless Steel...
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
No power Samsung WA8Ou3 washing machine
Possible that the main controller board is faulty if there is power supply to the unit. You can use a multimeter to check this out to confirm. Sometimes the power supply to the board can be faulty resulting in total failure of the board.
Feb 25, 2011 | Samsung Washing Machines
I have a Samsung LN-T1953H TV and the sound suddenly stopped working. We were watching a DVD and suddenly no sound. The TV picture still works fine but there is no sound. on any of the connections or...
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Mar 18, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
Where can i buy main unit board for my b550 set? help!
Sounds right to me, try calling 1-800-samsung to find nearest service/parts center.
Nov 15, 2009 | Samsung LN37B530 37 in. LCD TV
Samsung RS2534WW
Hello Mike , The main control board is on the right side in the back of the unit. look for where the power cord goes iunto the unit after you remove the cover on the back. there should be a large white plastic box on the right side. that is the main control board.
Dec 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Televison & Video Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
