Question about Samsung PL Cameras
Zoom didnt oprate normally
Also card error
    Genius:
  • Samsung Master
  • 1,019 Answers
The camera is going to require service.
Posted on Jan 25, 2013
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
Cannot get the card to work properly
JimmieReb,
Try formatting your original card in a PC - use FAT file system.
Then re-insert it into the Camera.
Feb 28, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
Zoom did not operate normally,insert the battery again and turn camera on again Camera doesn't operate normally
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
May 27, 2011 | Samsung PL120 Digital Camera
How do I zoom out my screen
either change the resolution via the display settings throught control panel to a bigger resolution or you could hold ctrl button and use the scroll wheel
Oct 21, 2009 | Computers & Internet
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
Zoom H4 Recorder Says, "Card Full!" But it is NOT!
I encounter this error with my 16 gb SD card and Zoom H4n.
I try to format the card inside and outside fo the Zoom, use 8 gb and 32 gb instead of 16gb card and, but get the same error.
But I find a solution.
1. I format my SD card inside Zoom with builtin utility. (Menu - SD Card - Format)
2. I reinstall Zoom firmware
(instruction and download here: http://www.zoom.co.jp/products/h4n/software/ )
3. I format SD card inside Zoom again.
I took a several test and didn't get a "Card Full" error.
Feb 16, 2008 | Zoom H4 Handy Recorder
Powers up and then shuts off
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2007 | Canon PowerShot A520 Digital Camera
Card Error
could be that the card is not formatted. if there is a setting in the camera to format it, try that, otherwise you could put it in a computer with a card reader and format it from there, with xp you just have to right click the card to get the format option. it could also be that the card is faulty (the brand shouldn't really matter). You may also want to take the camera in to a camera shop and have them have a look at it, make sure that the problem isn't in the camera. Good Luck
Jun 19, 2007 | Fuji FinePix A210 Zoom Digital Camera
Cameras Logo
42 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
